Old 07-20-2008, 09:21 PM   #1
c10crazy
Like a Rock!
c10crazy's Avatar
Rear shock relocators- How hard to install?
I thought there was a FAQ on installing these but I can't find it. If anyone has done this, was it a pain to grind the rivets off? Seems like it would be tuff to get the grinder up in there. Is CPP's kit the same as ECE's kit?
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 07-20-2008, 10:08 PM   #2
cdowns
cdowns's Avatar
Re: Rear shock relocators- How hard to install?
it sure is alot easier to do bedless//if you have a compact enough grinder the thing that makes it bad with the bed on is the grinnding residue seems to come right back at you// my favorite grinder nowadays is my 3"airpowered cutoff wheel
Old 07-20-2008, 10:12 PM   #3
c10crazy
Like a Rock!
c10crazy's Avatar
I plan to do this with the bed on. Unfortunately I'll be on the ground!
69 LWB
Old 07-20-2008, 10:30 PM   #4
Hart_Rod
Hart_Rod's Avatar
I can't speak for CPP's, but I've installed ECE's on my two trucks and am very happy with fit and quality. Invest in an air chisel, it will make the job much easier... Here's some pictures of my crewcab with them installed....
Hart_Rod is offline   Reply With Quote
Old 07-21-2008, 12:36 AM   #5
chevguy7
chevguy7's Avatar
I used ECE's kit. It was easy and fit was not an issue at all. I also had the bed off for grinding the rivets.
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs
http://67-72chevytrucks.com/vboard/s...d.php?t=272458
2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds
chevguy7 is offline   Reply With Quote
Old 07-21-2008, 02:10 AM   #6
blkboot
i just put 5 inch drop spring on my truck and it still sits up high in the back.i didnt change the pan hard bar nor did i use the shock relocators.do you guys think thats the reason why me truck still sit kind of high in the back???
blkboot is offline   Reply With Quote
Old 07-21-2008, 07:15 AM   #7
c10crazy
Like a Rock!
c10crazy's Avatar
Thanks or the pics Rob.
69 LWB
Old 07-21-2008, 08:20 AM   #8
67dragtruck
67dragtruck's Avatar
If you try to push down on the back or bounce will it go down or are the shocks bottoming out?
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 07-21-2008, 09:08 AM   #9
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
I just installed 6 inch drop coils in the rear from GMC Pauls and installed a Super Track Bar From ECE. I don't have a shock relocator kit or shocks yet. I plan on using Nitro Drop Shocks. Here's how my truck looks right now.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 07-21-2008, 10:51 AM   #10
matthufham
i had some boys come over and take the bed off real quick to grind the top rivits. the bottom nuts can be a *****. i got mine from cpp, the angle of the bottom brackets were off where the shock mounts. it wasn't flush, but i put a bolt through the hole/shock anyways even though the angle's off a little.
matthufham is offline   Reply With Quote
Old 07-21-2008, 10:58 AM   #11
VanceH
Loving the Jimmster
VanceH's Avatar
Ok silly question, but why do you need ot relocate the rear shocks??
VanceH is offline   Reply With Quote
Old 07-21-2008, 11:42 AM   #12
jb4short
Damn Yankee
jb4short's Avatar
It will be a LOT easier to install with the bed off. I've been taking the rivets out by grinding the top flat (just a little bit so your drill bit doesn't wander- could do the same thing with a punch) and then drilling a pilot hole with an 1/8" drill bit, then drill with a 3/8" bit...one quick blow with a chisel and they pop right out.
This just saves you from grinding the frame itself AND I've totally ground a head off and not been able to get the rivet out....with the drilling it works quick and easy.
The kit fits great and went in pretty painlessly
jb4short is offline   Reply With Quote
Old 07-21-2008, 11:44 AM   #13
jb4short
Damn Yankee
jb4short's Avatar
to decrease the shock angle when lowering a truck. When they're "Laid out" the shocks are really ineffective
Old 07-21-2008, 12:11 PM   #14
c10crazy
Like a Rock!
c10crazy's Avatar
Thanks for all the responses. I was hoping to hear from somebody who did this the bed on!
69 LWB
Old 07-21-2008, 12:21 PM   #15
Hart_Rod
Hart_Rod's Avatar
I did this to my Burb with the body on, it's a B@$#@#&. Take the bed OFF!
Old 07-21-2008, 01:01 PM   #16
chrislehr
Engine n00b
chrislehr's Avatar
1 hour per rivet if you have ****ty tools.
chrislehr is offline   Reply With Quote
Old 07-21-2008, 01:24 PM   #17
Riveted1
Tasty Cakes!
Riveted1's Avatar
I agree, if you have room, take the bed off. You will save time and will be less likely to get hot metal down your collar.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 07-21-2008, 01:28 PM   #18
faribran
Rob has the best advice..... zip gun/air chisel and use ECE stuff.
sure made the job easier for us.
faribran is offline   Reply With Quote
Old 07-21-2008, 01:29 PM   #19
aws68
I recently installed the ECE kit with the bed on. I followed the angle grinder / air hammer technique:
http://67-72chevytrucks.com/vboard/s...d.php?t=291939
It was a little tricky getting the angle grinder in there to grind the rivet heads, but if a rookie like me can do it, I'm sure you can. The air hammer was crucial, though. I borrowed my neighbor's Snap-On and it worked great.
aws68 is offline   Reply With Quote
