Eliminating the external regulator...
I'm wanting to finally get rid of my external regulated alternator,and I just have a few questions.
This harness from M&H is just a plug and play deal right? I don't necessarliy want to go to a one wire,so this should work correct? http://www.wiringharness.com/images/parts/27555.jpg The alternator I need is an SI series right? If you've done this swap,where did buy your alternator and what amp output did you go with??? |
Easy Does It
Re: Eliminating the external regulator...
I believe you can just ask for an internaly regulated alternator 1 wire at any auto parts store, then run 1 wire from alt. to horn relay. disconect the regulator and all the old wires you can toss. somebody tell me if im wrong because im getting ready to do this to another truck of mine.
Check out this article on the Mad Electrical website. Lots of information, and about 3/4 of the way down it discusses specific applications. That way when the parts counter kid asks what year, make and model you will have an answer!
![]() http://www.madelectrical.com/electri...elcoremy.shtml
The Stable: 1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me. 1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck. 1951 Chevy 1/2 ton, 3-window...building to sell. Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado. I grew up in Flint, Michigan so I can't help but to bleed Chevy! |
I know about the one-wire deal,but I want to keep my idiot light (cuz I'm an idiot.)
I do appreciate the help! |
#5 | |
Council of the Elders
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times Last edited by billydonn; 07-24-2008 at 07:50 AM. |
#6 | |
I found out what my problem was. The wire from the horn relay to the battery was VERY loose. My truck wouldn't start after after starting a few minutes previously. I was determined I was going to find out what the problem was,and that was it. I've only driven my truck 4 times since I put it back on the road in early June,and I've fought electrical problems. My lights were dim,the radio would crap out,and sometimes the truck wouldn't start,and the tach was jumpy. In addition,the truck didn't run nearly as good as it should. It sure didn't feel like it had enough power,but now it's running better. I still haven't turned the 388 loose yet though. ![]() I'm still going to do this conversion someday,but things seemed to be good now. My tach quits when you turn the headlights on though so I gotta figure that out. Oh,and my speedometer was acting up last night also! Oh the joy of owning an old truck!! Last edited by AllenKarber; 07-26-2008 at 11:29 AM. |
Easy Does It
I have a delco-remy alternator that I would like to use- can I change this over to a one wire internal regulated ? Is this something I can do ,is there a kit or web site that tells how or what ? Or is it beter to just get a new one? thanks
Easy Does It
actually I don't want the one wire, but I want to be able to wire this in to my truck and toss the regulator and any extra wires, heres a picture of what I have. Is there some kit I can use for these trucks-do I need a regulator for this/ thanks
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yes that is an internally regulated alternator. For info on installation just check out the links posted above.
#10 | |
PITbut
http://www.6066gmcguy.org/charging.htm should help you a ton. |
Easy Does It
ON the three wires coming off this alternator the battery post #1 should connect to the horn relay where the battery wire comes in to it, the brown wire from the amp gauge goes to #3 terminal -now for the #2 post- ignition switch what do I run that to ? could i route that to the red ignition wire from the harness where it connects to the horn relay?
1961 crewcab
I finally found the thread that helped me switch from external to an internal regulated alternator.
If you click on forums on this site, then the very first one says welcome area, click below thatwhere it says sub forum, faq site related. then scroll down to the external/internal post by todtheodd. I followed his instructions exactly and have had no problems since! |
#13 |
Its Deja Vu time again
Found this earlier if it helps any.
http://www.persh.org/pickup/UnderTheHood.htm#Alternator I read that fact page and its pretty good. Is that the same thing you would use on a 60-66 model? I didn't see what particular model it was installed on, but I'm guessing its pretty universal? Last edited by kizer; 09-03-2008 at 06:47 PM. |
#14 |
Schlongbed MEMBER (heh)#15
Wow,Great info here. I didn't even think to ask these questions.
82 Chevy Blazer 4wd.RIP 1965 Chevy C10,350V8 Get it reliable,then puttin' it in the weeds.. "Old truck, all new headaches." |
