Old 07-21-2008, 12:05 PM   #1
ronh72c10
Manual hubs you can engage from the cab? Do they exist?
Basically I'm looking for manual hubs for the front of my 72 K25 that can be engaged from the cab rather than by turning the knob on the axle. (Dana 44)
And no I'm not worried about getting my piggies muddy, , my wife is going to be driving it to pull her horse trailer and I'd prefer to have a dash mounted switch/lever so she knows they're disengaged.
Ron
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 07-21-2008, 01:41 PM   #2
1969K10
1969K10's Avatar
Re: Manual hubs you can engage from the cab? Do they exist?
In short, NO, they don't exist.
You can have a locker of some type (electric or air) that is activated in the cab. but that just locks up the front differential from a open diff to a locked diff.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 07-21-2008, 05:34 PM   #3
Blazer1970
Blazer1970's Avatar
There is nothing wrong with just leaving them locked all the time either.
Blazer1970 is offline   Reply With Quote
Old 07-21-2008, 09:06 PM   #4
ronh72c10
That's what I figured.
Thanks,
Ron
72 GMC 3/4ton 4x4
Old 07-21-2008, 09:26 PM   #5
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Won't you be spinning the front axles, ring gear, and drive shaft if left locked? maybe even the output shaft of the transfercase. wouldn't that cause increased wear on parts and decreased gas mileage? I could see leaving them locked in if you were out dirt tracking and didn't need 4x4 all the time. But, I wouldn't leave my hubs locked all the time. especially, if I was towing a trailer on the freeway.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 07-21-2008, 09:33 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Wait wait, not so fast!!
Warn Lock-O-Matic hubs have been discontinued for years, but if you can locate a pair, they just might be what you are looking for.
Basically, they are an all-metal (bronze/aluminum) manual hub. The difference is that for occasional use, you can leave them in "Free" and stop the truck (no shift-on-the-fly), engage 4WD, and go forward. The hubs will lock automatically. You can go back into 2WD on the fly and the hubs will release.
They won't stay locked in reverse, but they do a good job driving forward.
Of course, for serious off-road work you can lock them in, same as any other manual hub. Note: they are not spring loaded, so the splines need to be reasonably aligned before they will engage manually.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-21-2008, 09:35 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yes
- Mike -
RIP El Jay
Old 07-22-2008, 12:24 AM   #8
Blue_71
Bloo
Blue_71's Avatar
this is another possability too.. im not really sure what all these came on, but my 79 has full time hubs. under the dust cap, there is a flat metal plate splined to the hub, and to the axle shaft. its held on by a snap ring. more or less, keeping the axle locked in all the time with less moving parts
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-22-2008, 01:00 AM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Blue_71, I believe those require a NP 203 (chain drive) full-time transfer case... and won't work with a 205 TC.
- Mike -
RIP El Jay
Old 07-22-2008, 06:29 AM   #10
Blazer1970
Blazer1970's Avatar
Just the opposite. You need the hubs locked all the time for a stock 203 since it is a full time case. The drive slugs will work fine with a 205 or any other transfer case.
Old 07-22-2008, 08:33 AM   #11
ronh72c10
I saw a couple of lock o matics on ebay, but realistically if the only issue is that there'll be more wear and poorer fuel economy, the few times they're forgotten on won't be a problem.
Ron
72 GMC 3/4ton 4x4
Old 07-22-2008, 09:18 AM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Right, they are effectively fully locked at all times...
Guess I shouldn't have said they won't work with a 205. Of course you're right, technically they will work -- but you can never run 'em free so everything is spinning all the time. Not good for wear & tear or fuel mileage, so why run them with a 205.
- Mike -
RIP El Jay
Old 07-22-2008, 01:32 PM   #13
1969K10
1969K10's Avatar
Ron
FWIW, i see the biggest drop in MPG when i engage my hubs. Generally drops me 3-4 MPG. Wether I'm in 4WD or 2WD via the X-fer makes almost no difference to my MPG.
Old 07-22-2008, 10:10 PM   #14
RED72blazer
urban fourwheelin
wow, didn't think it would be that much
Old 07-22-2008, 10:52 PM   #15
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Well, you are spinning a lot of extra hardware, which means a lot of parasitic drag -- and this is very old hardware, designed long before fuel efficiency was much of a concern.
Never checked mine, but I sure can feel a big difference in 2WD with the hubs locked in.
Edit: As a side note, my work truck is a 2003 F*rd F450 4x4 bucket (lift) truck with manual hubs. It's virtually impossible to tell when the hubs are locked in 2WD. Maybe lighter oil in the front diff, maybe just bearings etc are designed for decreased drag vs our older stuff...
- Mike -
RIP El Jay
Old 07-23-2008, 08:08 AM   #16
When you know there`s a possibility of maybe needing 4wd it`s a good idea to engage you hubs to allow "shift on fly".You will only be running how these systems were originally designed before the lock-out hubs became an after thought.Sure,it`s best to run disengaged hubs whenever possible.If the wife isn`t running all over the place,I`d lock them in for her and be done with it.Even Loc-O-Matics require manually engaging when serious use is in place.They will grenade to smithereens when putting alot of load on them while in "free".Warns says "when compression braking and hauling loads" to engage to "lock".Well,running in mud that requires 4wd puts the same stress on the hubs as hauling a load or holding the weight of the truck back with the motor.
When there`s patchy snow I always run my hubs locked...right on down the hiway,no problems.It gets better mileage than with the t-case engaged.I don`t believe I lose 3-4 mpg either.I don`t believe I lose that running in 4wd.
Old 07-23-2008, 05:32 PM   #17
Blazer1970
Blazer1970's Avatar
I agree, not even close to that much. I would doubt if the difference would be measurable. Jeep has eliminated the front axle disconnect on their straight axle models, and lockout hubs have not been used for years. Those are new factory solid axle trucks that run the front axle locked in all the time. I don't think they would do that if there were a considerable fuel economy penalty.
