07-21-2008, 06:44 PM | #1 |
Cowboy Up
350 re-build, going in my 1968 GMC
here is some photos of the re-build 350....
[IMG] http://i187.photobucket.com/albums/x2/Cowboy_2010/m_97d1bb78bb89d61333599a201ed1cf51.jpg[/IMG]
1971 chevy k10 *Under the Knife* Chris Cary |
07-21-2008, 06:44 PM | #2 |
Cowboy Up
Re: 350 re-build, going in my 1968 GMC
07-21-2008, 06:49 PM | #3 |
Loving the Jimmster
Very nice, i wish i knew more about engines!!! I would love to do that. Again vere nice pics
vance |
07-21-2008, 06:55 PM | #4 |
Specs???
07-21-2008, 07:10 PM | #5 |
Cowboy Up
i don't know much about doing that stuff either, i am having having "berry's Machine" down in Mason City, Iowa do it. Really nice guy and not bad for price. also, he is welling to teach
1971 chevy k10 *Under the Knife* Chris Cary Last edited by 1987_3/4ton_chevy; 07-21-2008 at 07:12 PM. |
07-21-2008, 07:13 PM | #6 |
Cowboy Up
Going into a 1968 c2500. its a 350
07-21-2008, 07:22 PM | #7 |
Not to go OT - but I was born in Mason City, and I did my very first engine overhaul ('68 327) with Berry's in 1978 This is the light brown brick building behind what used to be Fairway Foods, right?
07-21-2008, 08:53 PM | #8 |
looking good, I am also curious what combo you are doing (specs)
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
07-21-2008, 11:27 PM | #9 |
Cowboy Up
yes that is berrys
07-22-2008, 09:08 AM | #10 |
What heads are those?Have you run /dynoed the engine yet?
07-22-2008, 01:52 PM | #11 |
Cowboy Up
The Heads are the orginal ones off the engine. There were no cracks so i am useing the same ones and they are good ones so ya. I have not Dynoed it yet... hopefully soon
1971 chevy k10 *Under the Knife* Chris Cary Last edited by 1987_3/4ton_chevy; 07-24-2008 at 02:01 PM. |
07-30-2008, 01:10 PM | #12 |
Cowboy Up
whats the best way to begine when you first start it? like it idle or take it out right away but not harming .. YET?
07-30-2008, 04:07 PM | #13 |
If you put a new cam in it follow the manufactures recs.Usually run it at 1500 rpm for 15 minutes then shut it down and check everything.I usually change the oil after running it a couple of hours the again at 50 miles then regular schedule,but Im really picky about new motors.
07-30-2008, 10:30 PM | #14 |
Cowboy Up
see "Berry's" the guys that are re-building it told me to take it out right away and slow get it up to 5- 60 MPH and back it off to about 30 MPH. Is that better or letting it idle?
1971 chevy k10 *Under the Knife* Chris Cary Last edited by 1987_3/4ton_chevy; 07-30-2008 at 10:30 PM. Reason: spelling error |
08-02-2008, 11:06 PM | #15 |
Drag Racer
Hey guys....to help clear some stuff up for Chris the engine is a 3970010 block, unsure of heads although i would assume stock heads with that block. Block was completely gone through, magnafluxed line bored, honed etc.
Installed stock intake, new bull horn style exhaust manifolds, orig. crank., new pistons and i THINK rods, pistons are stock compression etc. Installed a crane .440/.440 "266" grind profile camshaft. New oil pump, water pump, fuel pump, harmonic balancer, dist, etc. etc. Still has the orig. carb on it but i think he would gain a lot by going to a performance aftermarket carb, BG, Edel., Holley etc. Theres a ton of other small stuff hes done to it that doesnt really effect performance in any manner.
Zach Hall 1983 Chevy C10 R/T: .194 60': 2.322 330: 6.379 1/8: 9.803 MPH: 71.37 1000: 12.781 1/4: 15.314 MPH: 88.79 |
08-05-2008, 12:26 PM | #16 |
Cowboy Up
thanks dude.
I have a question, I bought these house braids... http://www.jegs.com/i/Spectre/865/7496/10002/-1 I am wondering if anyone has these on there truck? I know you gotta put the reg. hose in them but does the hose gotta be a size smaller to put in them or what?
08-30-2008, 12:07 AM | #17 |
Cowboy Up
hey,anyone know anything about these or use them? what u think about using them? good or bad?
08-30-2008, 01:06 AM | #18 |
This is straight from the machinist/engine builder that helped my build my engine. Basically do it like it was mentioned before. Fire it up(make sure you have primed the engine before you jump the gun) run it at high idle 1500-2000 RPM for 15-20 minutes then shut it down and check everything out. Once you have done this he said go find a big hill and go up and down it letting the engine compression brake you on the way down. Apparently this helps set the rings. Then break it in like you're gonna drive it. I've done probably 100 rebuilds on my motorcycle and this seems to be the best method, ride it like you stole it. I broke it in using the manufacturers specs once and first time at the track KABLOOYEEE, pop,pop,sputter, S!@#.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
