PITbut
Can i solid mount my transmission?
Im making a tranny crossmember and wanted to know if i could mount the transmission DIRECTLY to the crossmember. Its a th400 trans with 454 if it matters. It will be driven at least 2/3 times a week. Is it necessary to have the rubber mount in between??? Anyone know where i can get the rubber mount portion if it is necessary???
PITbut
Re: Can i solid mount my transmission?
its all about the +6 inches
any parts store can get it.
If you mou nt the tranny solid, but not the engine, you WILL break the tranny in 2. |
Saving 1 truck at a time!
Lyrikz, I have a parts truck with cross member and rubber mount for a TH400 if you want to pull it. I am on the East Hill in Kent.
Is your truck a 3/4 ton? I might have some other parts you may have some interest in as well.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 07-22-2008 at 12:53 AM. |
I got a polyurethane tranny mount from summit.
I'd do the urethane mounts as the BBC has a bit o torq and over time will tear the OE replacement types. As for the solid mounting I agree with the above, only if the motor is and then only in a race set-up.
![]() Join Date: Apr 2008
Agree with above if you solid mount it the case will probably crack.
PITbut
I bought some metal to make my own tranny crossmember. Im going to pick up a rubber mount and at least TRY this. If it doesnt work i will let you know.
PITbut
