Old 07-21-2008, 11:27 PM   #1
SBTork
Garage wrench
SBTork's Avatar
trucks with impala ss wheels?
I found a great deal on a set of '94-'96 Impala SS 17x8.5's. I don't think i've ever seen them on a square bodystyle truck. Does anyone have any pics?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 07-21-2008, 11:51 PM   #2
kevinr1970
Re: trucks with impala ss wheels?
I am pretty sure captkaos has them on a project (or shop?) truck. Find one of his posts and there might be a link in his signature.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 07-22-2008, 02:07 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Square body frame count?
http://www.captkaoscustoms.com/blazertank.html
http://www.captkaoscustoms.com/suicidal.html
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 07-22-2008, 06:39 AM   #4
rod86
great southern land
rod86's Avatar
hmmm i actualy like them...
rod
86 chevy c10 silverado
rod86 is offline   Reply With Quote
Old 07-22-2008, 10:50 AM   #5
454HO
I've got a set in the garage I am considering using on my '86. A couple things you should know if you decide to go this way.
First, there is a fairly limited range of low profile tire sizes for a 17" wheel. The stock ImpalaSS tire is 255/50 which is about 27" total diameter. You can squeeze a 285/40 on there, but the diameter will only be 26". If you don't mind a higher profile, 275/60 is a common size for SUV's and there are several high performance sport tires available. The overall diameter for this size tire is 30". If you want really fat tires, you can still get a 315/35 tire, but you will need to get the wheels widened at least 2".
Next is these wheels have a 6mm offset, which means about 5" backspace. There should not be any clearance isues, but this makes it look like the wheel is pulled into the wheelwell. If you want tucked, this is good. If you want edge of the tire even with the fender, then you will probably need some spacers.
There is a mid 80's long bed truck in my neighborhood that has ImpalaSS wheels on it. I will try and get a picture next time I see it.
Here are a couple pics I had saved on my hard drive -
- Greg
454HO is offline   Reply With Quote
Old 07-22-2008, 11:38 AM   #6
SBTork
Garage wrench
SBTork's Avatar
thanks for the good info guys. I don't think they look too bad, it'd be a cheap way to get some 17's on there.
If you see the longbox with the 17's snap a pic if you can.
-Adam
Old 07-22-2008, 12:01 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Here is my beater when it was running with them on it:
Here is a good view of the offset
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-22-2008, 12:29 PM   #8
SBTork
Garage wrench
SBTork's Avatar
^^not bad
-Adam
Old 07-22-2008, 01:12 PM   #9
Square84
I don't think these pills work
Square84's Avatar
ther was a thread awhile back about can our trucks pull off the patina look and capts truck is a perfect example that they can look good.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 07-22-2008, 04:35 PM   #10
piecesparts
Parts and more parts
piecesparts's Avatar
You could run the 255/50/17s in the front and a set of 275/50/17s in the back. I put this on my 91 Silverado and am getting a set of 17" rims with the same setup for my 84 GMC. The 275/50s are a 28" tire and work real well for daily driving. The Nitto tire line has them in the Nitto 450S series.
piecesparts is offline   Reply With Quote
Old 07-27-2008, 06:15 PM   #11
454HO
Sorry it took so long, but here ya go.
Don't ask me what size tires they are, 'cause I don't know anything about this truck other than I see it in the neighborhood from time to time.
- Greg
Old 07-27-2008, 06:46 PM   #12
bad6772
Official Site Guitar Shredder
bad6772's Avatar
RNGs not a square body but it shows how good they can look.Name:  rngs.jpg
bad6772 is offline   Reply With Quote
Old 07-27-2008, 07:16 PM   #13
COMP
looks good,,,i'd like to get a set of the turbine's in that one pic
COMP is offline   Reply With Quote
Old 07-28-2008, 02:14 AM   #14
SBTork
Garage wrench
SBTork's Avatar
thanks for getting the pic 454HO, that may be a bit too much tire for me, but it looks good. Thanks for the pics guys.
-Adam
Old 12-27-2008, 06:13 PM   #15
kevinr1970
Awakened from the dead...
Is $350 a good price for these wheels with usable tires?
2000 Tahoe Limited
Old 12-27-2008, 07:19 PM   #16
454HO
I would say so. These wheels usually sell for about $75 each in good used condition with the center caps from what I have seen. They used to be available from the dealer new for about $630 a set of 4, but I think they have been discontinued now.
- Greg
Old 07-17-2010, 01:17 PM   #17
primrrd
primrrd's Avatar
howdy all, lurker here.
I've been running the wheels on my 81 (5/5 drop)
the fronts fit good , the rears are too "tucked", but they were cheep (:
primrrd is offline   Reply With Quote
Old 07-17-2010, 07:47 PM   #18
gchemist
gchemist's Avatar
Wow, I thought that was my truck! Nice!! Welcome to the site.
Old 07-17-2010, 11:23 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Welcome to the site primrrd. Truck looks good. The front plate was playing mind games till I zoomed in on it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-18-2010, 01:26 AM   #20
gchemist
gchemist's Avatar
The upside down plate is to trick toll road cameras!!
Old 07-18-2010, 04:37 AM   #21
Pop's C-10
Pop's C-10's Avatar
.they look good
Pop's C-10 is offline   Reply With Quote
Old 07-18-2010, 04:59 AM   #22
SiCk_DiAbLo
SiCk_DiAbLo's Avatar
They 5 x 5 lug pattern, or did ya modify them??
1993 Chevy Silverado.
1984 Chevy Z28.
1972 Chevy Custom 10.
1965 Custom 10..FOR SALE
SiCk_DiAbLo is offline   Reply With Quote
Old 07-18-2010, 08:11 AM   #23
Gemp
Gemp's Avatar
Their 5x5.......
06' GMC 1500 Crew cab.....
Gemp is offline   Reply With Quote
Old 07-18-2010, 08:54 AM   #24
68 TT
Still plays with trucks
68 TT's Avatar
Truck looks great.
You can pick up an 88-up new body style truck rear end and put it in there.
glock35ipsc just did this with his project Fred. They are a little wider and will push the rear tires closer to the lip so the front & rear look closer to the same.
It takes a little work but you can get better gearing and a posi for your truck at the same time too.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 07-18-2010, 09:50 AM   #25
N2TRUX
Happy to be here
N2TRUX's Avatar
Hows that work? They shoot the pics from the rear too.
Articles-
"Refining Sierra"
