help with speedo
my speedometer has made noise on and off for years.i pull the cable squirt some lube in there,and it's o.k for awhile.i haven't had to do it in a long time.i was getting a loud screeching sound.now after reinstall .i'm getting a horrible snap and pop.bad enough to where you need to totaly unhook it.i can't rememeber if you have to push the upper speedo clip in to insert in the back or not.mine just snaps in without pushing the clip in.but,you gotta push the clip to remove it.about ready to leave it unhooked since it's way off anyway due to tire size.any ideas?
" Never look up a dead dogs butt." ![]() |
Manual Transmission Club
![]() Join Date: May 2008
Re: help with speedo
You should never ever wear a Speedo!!! Hope that helps...
79 GMC Sierra Grande, SWB, Heavy Half If I wanted easy I would just buy a NEW truck! |
BAD BOW-Silverado XST
First fix your speedo gear ratios.
http://www.tciauto.com/Products/Tech...eedo_gears.asp http://www.73-87.com/7387garage/drivetrain/speedo.htm Use grease instead of oil to lube the cable. Grease will last longer. You have pull the entire center cable out to grease it. |
While we're on the subject, what's a good grease to use for the cable?
#5 | |
Arrived on a Pale Horse
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
You have to push the metal bar to remove it. I should push on without anything. If it is snaping/popping, remove it from the trans side and see if it is mangled. It may need the cable replaced. Pull it out and if it is ok, lube it and put it back in.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
thanks cap'n.....i thought that's how it worked.just couldn't remember if you had to depress the clip to reinstall,i haven't been. and gchemist,thanks for the links..........and the rest of you joker's.you should hold your speedo comment's to yourself. at least till you recieve the pics of me in mine.which i'll be emailing you.because i know you want them
" Never look up a dead dogs butt." ![]() Last edited by boatpuller; 07-22-2008 at 05:59 PM. |
Use a light lithium grease. Bearing grease is too thick. A light grease works great.
#9 | |
nah...not looking to get anybody back.
I got it, thanks.
#13 |
good one
