07-22-2008, 05:01 PM | #1 |
my little project
First off, this "build thread" is starting halfway through the build.
It all started back in december 07 when i decided that i needed a new project. I always wanted an old C10 and i happened to see one for sale in the local trading post.. so i went out and looked at it. It was very rusty. the fenders were rusted out, the rockers, cab corners, Apilars, and radiator support. but it was a 68 short fleet, and the floor of the bed was solid with only surface rust. NO rust through. It had a mid seventies 350 in it that the owner told me had ran the previous summer(that was a lie) and it had previously been wrecked and somebody put a 69 front end on it. anyway..for $1500 dollars i fugure the tuck was worth it. heres some pics of what it looked like when i first got it. Last edited by bdydrp97s10; 11-20-2008 at 10:20 PM. |
07-22-2008, 05:28 PM | #2 |
Re: Her name is "Ralph"
Then the first thing i was concerned with was getting the crappy 350 running.. everything was disconnected and halfway taken apart which leads me to beleive that it never previously ran.. and the fact i couldnt get it to run. and i tryed for a few days..
so i just yanked it out(at this point i wasnt sure if i should rebuild or buy a crate, you will see later though) so project number 1 for the truck was 5 lug swap. i started by getting a 73 up front cross member from BILLSBOWTIE on here. Hes a great guy to deal with by the way. and i switched the brakes over to a power brake booster i got from BARRYB(another board member).I also got the 5 lug rearend from him but i have no pics of that install, but im sure you could imagine. I also had to cut out that front crossmember that a PO hacked up for no apparent reason and replace it with a good one from BILLSBOWTIE. And i ran all new brake lines from front to rear-hard lines and hoses- everything was all brand new so i started by cleaning the frame off and getting it ready for the new crossmember.. heres pics of the crossmember from bill. and all the new brake lines |
07-22-2008, 05:39 PM | #3 |
this brings us up to february now.. its time to start body work
heres some before shots of the truck and body work.. and the grille i bought from BILSBOWTIE. i had to do a little repair on it.. it had a bullet hole in it and the rocker panel that was missing i had ripped it out with my hands.. the PO or whoever "fixed" the truck the first time did an awesome job of welding and bodywork.. the doors were both rusted through and they just slapped bondo in the rust holes on both sides and called it good. both doors had rust throuh like the one in the pics. heres pics |
07-22-2008, 05:47 PM | #4 |
more grille and body work pics
07-22-2008, 05:49 PM | #5 |
by this time its march and i have bought a crate engine and had my turbo 400 rebuilt
07-22-2008, 06:01 PM | #6 |
and im still doing busy work at this point trying to get everything straight, ive bought a brand new set of 20"rims.
Ive put the engine in the truck, and i installed an EZ wiring 12 circuit harness. i installed two aftermarket fenders, and the right hand door is aftermarket too. BUt the engine starts and runs fine- and bodywork is 95% done after installing inner and outer door bottoms on the driver side i decided i wouldnt do that again. But im still having problems getting the gap between the fender and hood right.. Its really tight in the back on the hood but at the front it has 1/2" gap on both sides.. and i cant bring the front of the fenders on because the grill holds them aprt.. so im stumped for now. any body have ideas?? heres pics of how it sits as of now- 6 months later.... keep in mind the engine is just wired up to make it run. I will clean it up later |
07-22-2008, 09:12 PM | #7 |
Hey looks like your on the right way to recovery. Keep up the good work, and for when you can't find something to do.JUst remember I still have this one over here in Blountville that is crying for some attention.
P.S. I like those wheels, what kind and where did ya get'em
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 07-22-2008 at 09:14 PM. |
07-22-2008, 11:58 PM | #9 |
Still livin the "dream" in '54
I have to respect the '67-'68 grille.... but shave the side markers... imho
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
07-23-2008, 01:01 AM | #10 |
teh wheels are boss 335's. i got them from a friend of a friend who owns a used car place but also sells new rims in kingsport.
the wheels were $1550- that was for the wheels brand new, new tires, all the lug nuts, and mounting and balancing
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333 |
07-23-2008, 11:36 AM | #11 |
Skinned knuckles
Nice progress!!
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
07-25-2008, 10:34 PM | #12 |
Under Construction
lookin good...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
07-26-2008, 10:02 AM | #13 |
PROJECT 7DEUCE
Looks like she is gonna be a sweet ride when shes done..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-27-2008, 10:46 AM | #14 |
looking really good!!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
07-28-2008, 01:53 PM | #15 |
this weekend i didnt get much done my girlfriend came over, but i gave her some old work cloths and made her help me.. i just had her sanding the rotors, and i had her install the calipers
I had to put longer wheels stud in the rotor because i had to put wheels spacers on the truck because the centersap wouldnt fit on the truck. heres some pics
07-28-2008, 02:28 PM | #16 |
Tot Roddin'
Nice progress... keep up the good work!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
08-06-2008, 12:34 PM | #17 |
Good to see the woman getting dirty and helping. Nice progress on the ride.
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo Last edited by Richard8971; 08-06-2008 at 12:35 PM. |
08-07-2008, 07:28 PM | #18 |
Step Brother
Looks great....Nice truck...
10-27-2008, 08:23 PM | #19 |
thank you for the comments
not too much progress right now, im still trying to raise the cash for a paint job
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333 Last edited by bdydrp97s10; 10-27-2008 at 08:24 PM. |
12-21-2008, 10:30 PM | #20 |
UPDATE---ok i had to put new cab bushing under it because the cab was sagging and then i had to realign all the front end pieces..
so now im going to fab up the exhaust this week, so my friend can come over and set the timing and adjust the carb.. then its off to to paint, if the paint guy can get it done in time.. he told me today he wasnt sure if he could have it done by march, he tells me his body dhop is slow on work right now, so hes working on his house boat. and im trying to send him some work but i guess he would rather work on his house boat... doesnt make sense to me, but i guess he has wnough money(must be nice) so ill be looking for another painter. uggggh
12-21-2008, 10:37 PM | #21 |
ill be sure and take pics of the exhaust install i know you all love pics..
12-21-2008, 11:05 PM | #22 |
VA72C10
Looking good...nice work so far
Looking for a 67-72 swb or blazer project in or around VA. |
12-22-2008, 01:31 AM | #23 |
way to go, paint is always expensive, i know b/c that is what i do, even i do not have enought money for it, thank god that my shop lets me charge it and work it off, really like the looks of your truck!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
12-22-2008, 01:37 AM | #24 |
Lqqkin good
bob m |
01-03-2009, 12:40 PM | #25 |
Mr. Thread Killer
