tires?
hey guys, looking for some new tires for my truck.
its going to be a real daily driver, but i want the tires to have at least a little bite when i go in a strait line. something in the neghborhood of a 28 inch tire, about 12.5 inches wide and 15 inch rim. I was looking at some BF goodrich Radial T/A's... are those any good? what other tires would you recomend?
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
mini truck racer
Re: tires?
The bfg t/a radials have a wear number in the mid 400s . General grabbers are like 360 . A true drag radial will be in the 40 to 50 range . Nitto drag radials are 100 wear . Unless you buy a drag radial most true radials are going to be in the 300 or above range . Hankook makes a tire that is in the 200 wear range and is R rated . Might check into those . Might not be avalible in 15" though .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Re: tires?
I have a set of M/T Drag Radials but they are about 30 tall.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#4 | |
Re: tires?
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
Re: tires?
They will be softer so you could assume they should "bite" better.
My Toyo Proxes are some of the better street tires I have tried. They are a true street tire so they dont grip as good as the drag radials.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
