Old 07-22-2008, 07:16 PM   #1
bdydrp97s10
bdydrp97s10's Avatar
body line ?
Is it just me or has anyone noticd that the body line in the bed sits higher than the body line on the cab.. in other words they dont meet up correctly..
Is there a reason for this?? are all 67 -72 like this.. alot i have seen are
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333
bdydrp97s10 is offline   Reply With Quote
Old 07-22-2008, 07:34 PM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: body line ?
No, it shouldn't be like that, although a lot of them are. It is usually the result of worn sagging cab mounts, although I had a truck once that I had to shim new cab mounts to make it match. The bed bolts to solid mounts, so without fabrication, you can't adjust it. Just adjust the cab up and radiator support up to the level of cab and you're good.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 07-22-2008, 08:00 PM   #3
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Re: body line ?
this what your seeing?
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 07-22-2008, 08:05 PM   #4
bdydrp97s10
Re: body line ?
check my build thread.. and look at my last post.. youll see what i mean.. alot of the trucks have it..
i figured it might be hte cab mounts
Old 07-22-2008, 08:31 PM   #5
67_C-30
67_C-30's Avatar
Re: body line ?
You're right, it is pretty common,
My trucks
Old 07-22-2008, 08:46 PM   #6
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Re: body line ?
WOW the GReen and Black ones look horrible once pointed out.
cant see it being a hard fix tho
496/T-56 in worx.
Old 07-22-2008, 08:58 PM   #7
Sicmaro
Always wrenching!!
Sicmaro's Avatar
Re: body line ?
the yellow one is mine, it deff needs new body mounts......
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
19 RZR XP4 turbo Dynamix
56 Belair 5.3/4L60E swap in progress
Sicmaro is offline   Reply With Quote
Old 07-22-2008, 09:03 PM   #8
67_C-30
67_C-30's Avatar
Re: body line ?
My red '69 was like that when I got it, and they fixed mine. I was collecting pics of trucks that were like mine is reason I had the pic of your's.
My trucks
Old 07-22-2008, 09:15 PM   #9
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Re: body line ?
hrmm i hope you understand by when i said horrible it was in regard to the lines not matching up. not your truck itself.
496/T-56 in worx.
