Old 07-22-2008, 07:34 PM   #1
72truckster
Thick or thin cab bushings?
I have searched for an answer but cannot find one. I got a new set of rubber cab bushings with my truck. So I want to give them a try. However they are a different thickness. Are they supposed to be? also Im sure they are not for the rad support. So can anyone please tell me if the thick ones go to the front or back of the cab. It is a complete frame off resto, so I would like to get this right before the doors and fenders go on.
Thanks.
72truckster is offline   Reply With Quote
Old 07-22-2008, 08:09 PM   #2
JimKshortstep4x4
Re: Thick or thin cab bushings?
Are you working on a 2 wd or 4 wd?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-22-2008, 09:02 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Welcome to the board... We could use a little more information (well a lot really...) Good rule of thumb. If you ask a question, supply as much info on your truck as possible. Even if it doesn't seem relevant to the question you are asking there are a lot of variables on these old rigs. By the way, this is not a flame, just a heads up...
1/2 ton or 3/4 ton? Chevy or GMC? High hump or low hump? I'll take a stab at it with the limited info but it may not be relevant... The rear cab mounts on 3/4 ton frames are mounted lower on the frame, so the rubber mounts are thicker. The front ones are the same, 3/4 & 1/2. If your frame is a 3/4 ton those would work, if not you will have to get a set for a 1/2 ton frame... Maybe..
LockDoc
Leon
Old 07-23-2008, 12:11 AM   #4
CPNEJR
CPNEJR's Avatar
i believe that the thicker mounts should be in the rear no matter what it is because of the design of the floor.
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 07-23-2008, 01:03 AM   #5
72truckster
Thanks for the replies and welcome. It is a 2wd, 1/2 ton. I converted the trany hump to the higher bolt in so it clears the tranny. When I look at the instructions for the energy suspension bushings there is different part # to use for the front or back bushing. For that matter, I have looked at the various part catalogue pictures but cannot figure out where the thicker ones are supposed to go. The problem is that the ones I have, came free with the truck, with no instructions. I suspect that if someone out-there has replaced theirs then they would be able to tell me if the bushings are supposed to be a different size and location.
Thanks.
