have a cuple of questions
ok i have a 75 lifted chevy blazer that has a sb 350 turbo 350 trans and a np 203 case but i want to change the case to a np 205 and change the rearend to an 8 lug and drop the 6 lug but i am sure that i need a new drive shaft and i want to do it all at once so can i buy the new shaft now and it will bolt up to the new rearend or should i wait and have everything ready and measure and get the new shaft made after i install the new rearend and t case
LIFTED OR LOWERED EITHER WAY STOCK SUCKS 75 Chevy blazer 86 trx 250R 1990 Ford Ranger 2wd prerunner project |
#2 | |
Re: have a cuple of questions
1968 GMC, 2wd to 4wd conversion, automatic to manual, 4 in custom lift, 36'' military tires, recent 454 upgrade 1979 Pontiac Firebird, mildly built sb 350, t56 trans |
ok and is one shaft better or one that is like a 2 piece
so is a one piece also stronger
ok and to get the measurments i need to do something like a triangle correct from yok to yok directly and from yok down to the heighth of the other yok and straight across from that point correct and if not how
I measure from the center of the yoke to the center of the yoke. Straight line.
ok then angles in the drive lines you said something about which one to go get(one piece or two) depending on angles how do i know or should i just get a one piece for sure
Dually Pride
depends on if you lifted it..one piece is fine up to 6" i assume
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually ![]() '94 Ford Ranger |
The two-piece design is basically about length. As the shaft gets longer it also has to increase in diameter to maintain it's "torsional rigidity". Meaning that if it is too long/skinny....it will twist, rather than drive the pinion.
Having a two-piece shaft cuts out part of the tubing, making each section shorter. I have never seen a two-piece driveshaft in a Blazer, it is just not long enough to ever worry about it. |
#13 |
Chevys Kick A$$
^I gotta agree I have never seen a 2-piece drive shaft in a Blazer yet. I think the easiest way to measure too is from yoke too yoke but I may be wrong.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
#14 |
but the two piece would be better for crawling because it has room to move as the body twist or articulates so the 2 piece shaft therefor would be better for crawling and out playing on trails right
#15 |
The clearence that you might gain in the middle of the shaft could be helpful on a LBW truck, on a Blazer you are just gaining too much angle at the lower joint. The more lifted....the worse this would be.
#16 |
wait until last on the drive shaft. longhair is right own the drive shaft being one piece in the blazer. because of the short wheel base.
one other thing that you may want to think about when having your shaft built is the joint size. since you went to an 8 lug rear it may have a larger joint. i like having all the same size joints on my rigs. it can cost a little more for matching yokes, but alot less agrivating. one spare joint fixes all. i like to keep it simple. Last edited by BIG HEAD; 07-27-2008 at 01:45 PM. |
#17 |
oh ok thank you for all your help it was extremly helpful
