Old 07-22-2008, 10:11 PM   #1
05Gibbs
05Gibbs's Avatar
laying out?
well to start off i have not posted much on here yet but i just bought a 65 short wide big window with a 283 auto trans all trim is there but needs lots of work...but anyways im wanting it to lay out and i know im going to get the front z'ed but i need to know how much and what is the best set up for the rear i do not want to back half it...i would like to see some set ups if people would post them but the main thing im worried about is putting a notch in the back with the crooked frame rails...im just stumped on what to do how close will it come to laying with a bolt in notch and using stock arms and just putting bags where the coils go?? but anything will me much appreciated thanks alot
05Gibbs is offline   Reply With Quote
Old 07-22-2008, 10:53 PM   #2
05Gibbs
05Gibbs's Avatar
Re: laying out?
another question is the rear frame section of my truck just like one a a 67-72 with coils?
Old 07-22-2008, 11:27 PM   #3
scotts62
One day...
scotts62's Avatar
Re: laying out?
crooked frame rails.. is it bent bad? Do you have any pics?
Scott
93 crew cab build
Project 62
Old 07-23-2008, 02:27 AM   #4
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Re: laying out?
i think he's refering to the "factory" bend over the axle.
Look into a Drop Member before you "z" it may seem expensive upfront but really isn't. The link in my sig. can take you to my build which shows the install is pretty easy. 2" Z is really all you need to lay frame flat up to 22's but I've seen guys do more.
if you do have the 2 link rear all you really need to do is get a KP Components or one of the other venders notches. make sure you tell them you want to lay out on (X) size wheel. some are deeper than others. Your links will bottom on the frame long before you lay out. To correct this add 3 or 4" blocks to get the axle up higher. you'll also want to make a longer and adjustable panhard bar to replace the stock one. there are several trucks on the board that can show you how it's done. Frizzle Fry's Tahoe is a good one to look at as well as Gringoloco's blazer.
Take a few mins to look around and you'll see plenty of similar rides "getting down" and almost as many ways to do so.
JB
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 07-23-2008, 05:35 PM   #5
05Gibbs
05Gibbs's Avatar
Re: laying out?
ok sounds good thanks
Old 07-23-2008, 05:35 PM   #6
05Gibbs
05Gibbs's Avatar
Re: laying out?
where can i buy the drop blocks for it?
Old 07-23-2008, 09:45 PM   #7
05Gibbs
05Gibbs's Avatar
Re: laying out?
i cant seem to find any pictures of one laying out with stock arms? if anyone knows where some are please point them out to me ha ha
Old 07-24-2008, 01:57 AM   #8
RunninLo
RunninLo's Avatar
Re: laying out?
I think any standard drop block kit ( djm, bell tech, etc.) will work. The last one I did was a '68 w/ 454 and a tacky late model fleet bed. I ended up building a "drop perch" that welded on in place of the stock perch but basically had a 4" drop built in. That allowed me to dial in the pinion angle with out using shims. Sadly while I took tons of pics of my cups anmd plates ( pretty much same thing everyone else comes up with) I can't find any that show the rear other than the bag placement. One other trick I used on the '68 was to flip the lower shock mount/ u bolt plate over and swap left to right. It gives just a little bit more room for the shocks.
Josh
best rear pic I could find
88 4x4 crew DD
