Forever Grateful
HOW MUCH STALL DO I NEED RUNNING A HOT CAM @ .650 LIFT????????????????????????????????????????????
R.I.P Dad 04-07-42 - 05-27-09 |
Need more info than that to help you pick the proper stall.
1) Is it a sb or bb chevy? 2) whats the weight of the truck? 3) whats the rest of the engines combo like carb,heads,headers,compression,etc? 4) what kind of trans/ rear end gears are you running?
Life is good with a 6-71 supercharged 355 in a 72 camaro ![]() |
Cam duration and lobe separation? Each cam has a recommended stall.
Forever Grateful
468 BB,12.8 TO 1 COMP,4150 HOLLEY FLOWS 980,TEAM G INTAKE,781 OVAL PORT HEADS CUT OUT FOR 2.19 VALVES,HOOKER SUPER COMP 2" TO 3 1/2" EXHAUST,4.11 POSI TRAC,TRUCK WEIGHS I GUESS AROUND 3800LBS...THE ONLY THING I KNOW ABOUT THE CAM IS THAT ITS A FLAT TAPPET CAM W/650 LIFT...IF I CAN REMEMBER THE WAY HE WORDED IT- FLAT TAPPET 650 W/650 LIFT I THINK........OH YEA THE TRANNY IS A T400
[This message has been edited by RED67 (edited May 08, 2002).]
With those specs, I would guess fuel mileage is not a priority. A quality 3500 rpm stall converter would be a good starting point for this combination.
What are you planning to use the truck for? Race,Street/Strip,Daily driver... Do you have anyway of finding out the cam specs?You really need the duration and the LSA to make a reasonable choice for a converter. I'm just guessing, but based on the intake, compression, and the fact that it's a solid you've got a real hot street machine or bracket racer in the works.
72 SWB parts and pieces Oklahoma |
I'd call up a company, that way if its wrong, you have an argument to get your money back.
------------------ '69 CST Short fleetside Lowered, 400 small block, 700R4, 3" dual exhaust, 40 series Flowmasters, 4 wheel disc brakes, all stainless hard and flex lines, front & rear sway bars, Dana 9 1/4" rear end 4.11's w/Detroit Locker, soon to have 18" rims Not my daily driver. More like my weekend A$$ KICKER. See my truck at: http://www.geocities.com/low69cst/ Future Automotive Engineer attending the University of Kentucky. Feel free to message me on AOL, SN- SS95ZQ8 My Dad's projects: 72 Short Fleet 4x4 Chyenne Super 72 Long Fleet 4x4 Chyenne Super Both 350 autos restored original
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
I have a .500 lift I believe, on a high compression 350. I talked to a guy that said 3500 to 3800 rpm stall. I'll probably look or one around 4000 stall, just to be on the safe side. If your driving it on the street though with that high of a stall, make sure you have a good tranny cooler.
1967 was a good year |
With that much stall you'll need some low gears to go w/it.
3500 RPM stall is pretty rough in a street machine. I hope you don't plan to drive around town much. You should check to see if it will interfere with highway cruising too.
Never tire of doing what is right II Thess. 3:13 Northeast Missouri 71 LWB original 350 3/speed Soon to be 500 |
Well with a big block you should have a good bit of torque to get off the line and it will help the converter stall a little more than normal.
I would use around a 3,000-3,500 stall if it was on the street with the 4.11 gears. If its a race/bracket style I would go up to about a 3,500-4,000 stall. BTW dont get a cheap converter!!!! also get a good trans cooler with a fan on it to be safe.
