Old 07-23-2008, 03:43 PM   #1
Purs
Got Big Block?
Purs's Avatar
2.5" lift options
I just want a modest 2.5" lift to get the stance just right on my '72. I've never messed with leaf springs so I'm a complete noob when it comes to lifts. Do I want springs all the way around or can I live with blocks in the rear? Should I buy shocks with the kit or get them seperate? This will be a mostly street driven blazer and I don't want to break the bank buying the lift. Is it too much to ask to find a good riding, easy to install, economical lift kit?
Oh, and if anyone wants to help install it, I'll have all the ice cold adult beverages you can drink.....
Update: found this kit, is it total junk? http://www.4-wheel-drive-lift-kits.c...on-lift-k.html
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 07-23-2008, 04:39 PM   #2
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: 2.5" lift options
I think 2 inch would give your blazer a nice stance, i'm planning on going with something similar. That kit is 461 with shocks which I don't think is bad. You will still be unlevel in the rear though about two inches. Contact the complany and find out how hard it would be to swap the rear springs for 4 inch springs and if the cost would be affected.
Oh and it's really easy to do, just get out the breaker bar to get the old bolts off and start spraying them with PB blaster or another penetrating oil now.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 07-23-2008, 04:58 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I am assuming that is yours and you wanna keep the wheel/tire set-up it has right?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-23-2008, 05:10 PM   #4
Purs
Got Big Block?
Purs's Avatar
That's correct.
Old 07-23-2008, 05:17 PM   #5
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Do you run a hardtop ever? If not it shouldn't sag much in the rear I was told
You can get a shackle flip for the back to avoid blocks.
68SWB4x4 is offline   Reply With Quote
Old 07-23-2008, 05:19 PM   #6
Big J
Its lookin' like a Blazer!
Big J's Avatar
You could always have the springs rearched and bring it up some. Look in the yellow pages under spring.... Great lookin' K5.
Some other choices
http://www.topguncustomz.com/Store/products.php?S_ID=65
If I were going through the knuckle bustin' fun of installing a lift I'd go 4". Not to high but you can run 35's on the road and still look good on with what you have now.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 07-23-2008, 06:04 PM   #7
Purs
Got Big Block?
Purs's Avatar
I'll only run the top when I have to, I'll check on having the springs re-arched too
Old 07-24-2008, 10:04 AM   #8
ebbmaster
That's a good kit. Haven't used that exact one, but Tuff Country is personally my favorite.
ebbmaster is offline   Reply With Quote
Old 07-24-2008, 10:18 AM   #9
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'm pleased with the Tuff Country springs I've used in the past. For your intended usage I wouldn't be worried about any problems using blocks in the rear.
If you went with the shackle flip your rear axle is going to move forward a bit and that tends to look odd in the wheel well. A Zero Rate from OffRoad Design will get it back to where you want it but that would add yet another inch of lift.
Good luck and keep us posted. Sure is a nice K5.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-24-2008, 11:23 AM   #10
Critter
Future TOTM Winner
Critter's Avatar
Where exactly are you in West Texas?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 07-24-2008, 11:42 AM   #11
Jtrux
Jtrux's Avatar
I hope we don't have another one from SabinALL
Old 07-24-2008, 11:59 AM   #12
Purs
Got Big Block?
Purs's Avatar
Abilene
Old 07-24-2008, 12:13 PM   #13
Jtrux
Jtrux's Avatar
Originally Posted by Purs View Post
Abilene
looks like I'm gonna go with the Tuff Country 2" kit but can someone that has tried these tell me whether to get the shocks with the kit or buy them seperate? Here are my choices:
SX8000 Nitro Gas Shocks $160
or
SX6000 Hydro Shocks $152
Remember I'm looking for ride quality not Off Road Performance.
thanks!
You might consider an adjustable shock is comfort is what your going for. Rancho 9000's are nice and have a good range of adjustability. Bilstein also makes several very nice shocks that i've heard give a very good ride quality but I think they cost the most. Look for Bilstien 5100's I believe. AJ72 has them on his truck, maybe he can chime in.
Old 07-24-2008, 12:40 PM   #14
AJs72K5
AJs72K5's Avatar
I'm running 5125's on mine. Great ride. Like Jtrux said, they're not cheap....about $85 each. The shocks you choose are just as important as the spring. Lousy shocks will make even the best springs ride terrible.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 07-24-2008, 01:14 PM   #15
Jtrux
Jtrux's Avatar
Yeah but i'm sure they're worth it.
Old 07-24-2008, 01:22 PM   #16
ebbmaster
Abilene
or
thanks!
If you're going with the shocks on the site, you should get the 8000's. Those are designed for full-size trucks. The 6000's are meant for small and mid-size. The 8000s are good shocks. The nitrogen gas pressure will reduce "fade" and gives quicker shock response compared to the hydro shocks.
