Now the others dig........
![]() Join Date: May 2002
Gas tank sending unit?????
Are all years of sending units from 67-72 compatible...i have a 71-72 tank that I want to put in my 68, will the 68 sending unit work and/or fit???? or do I have to have a 71-72 unit???
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
![]() Join Date: Mar 2000
Depending upon the tank you may have EEC vent lines to cap off but you can use any 67-72 fuel sender for in cab tank in any 67-72 fuel tank. There can be differences that need overcome such as vent lines or diameter line and type of connection as V-8 and 6 cylinder used different diameter fuel line and connector but you can use a adapter to join them. So the answers yes, but mods may be required.
GMCPaul |
ok
Paul,
now, the Vin number will tell me if the fitting from the fuel line to the sending unit is for a 6 cylinder or V8.....is that fitting universal for either 6's or V8's. If i do find that it is was originally a 6.....do I need to get a sending unit for a 6???? Thanks -Roger
