Old 07-23-2008, 06:39 PM   #1
Chevyman680063
Chevyman680063's Avatar
Stepside bed removal
Anyone have any tips on removing a stepside bed? I have the bed unbolted and the tailgate off. I wanted to take the fenders off before I tried removing it but the bolts/nuts are rusted together. I tried tightening the nuts to see if they would snap off but they just spin in place since the original bolts have a phillips head and can't keep the screwdriver from slipping off. You think I could use an air chisel to take off the bolt heads without damaging the inner bedsides? Thanks in advance.
Chevyman680063 is offline   Reply With Quote
Old 07-23-2008, 06:49 PM   #2
65chevy4x4
Re: Stepside bed removal
I took my fenders off my stepside bed last month.I use a small grinder with a 4-inch cut off wheel.I cut the nuts off had the fenders off in no time.
65chevy4x4 is offline   Reply With Quote
Old 07-23-2008, 06:54 PM   #3
Chevyman680063
I have an air cutting wheel too and thought about trying to cut the heads on the bolts as much as I could without cutting into the bed then trying to chisel off what's left since I don't have an air grinder yet. That's the next air tool on my list though.
Old 07-23-2008, 11:56 PM   #4
TN67chevy
TN67chevy's Avatar
i tack welded the bolt then removed the nut or snapped the bolt.then me,cherry picker,and 8 yr old son set it off
TN67chevy is offline   Reply With Quote
Old 07-24-2008, 12:18 AM   #5
2bits
2bits's Avatar
I used a ratchet with a socket, I think mine were the hex pattern. I couldn't get them all off, and I gave up and just put the bed on as it was. No access to air tools...
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 07-24-2008, 01:58 PM   #6
72armyswbtruck
72armyswbtruck's Avatar
Try an Impact Hammer (doesn't require any air tools and can be had for around $30 bucks thru craftsman)
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 07-24-2008, 02:54 PM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
Almost all of mine were shot, so I used a grinder as mentioned above. Just go slow and when the head starts to get real thin, you can pop it off with a chisel & hammer smack, or punch it through the hole.
Oh, and don't wear shorts and a T-shirt, I burned the hell out of my forearms and legs
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-24-2008, 09:15 PM   #8
rscam
I used a 5/16 drill bit and drilled the center of the head where the Phillips screwdriver goes. Just like you would drill out a rivet. You don't have to worry about cutting into the bed sides that way. It works great.
rscam is offline   Reply With Quote
Old 07-25-2008, 12:15 AM   #9
2bits
2bits's Avatar
I like that, I will try it before I have the truck painted!
_______________
Thomas
'78 Silverado
'74 Monte Carlo
Old 07-25-2008, 08:52 PM   #10
rscam
I only thought of that because I had to take a fender off at a junkyard and you can't really get a grinder in the junkyard. But I had a battery drill with 4 batteries. So thats what I came up with. You may have to hit the screwheads with a hammer if you don't drill them exactly center.
Old 07-25-2008, 10:08 PM   #11
chip46wis
I welded a 1/2 nut on each phillips head screw---the heat loosens the thing up and they come right off with a couple wrenches
chip46wis is offline   Reply With Quote
