07-23-2008, 11:06 PM | #1 |
Ignition lock cylinder removal???
I bought a new cylinder for my switch but I donīt know how to install it.. removing the steering wheel??
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
07-23-2008, 11:31 PM | #2 |
Re: Ignition lock cylinder removal???
i'm glad you brought this up, i need help with this as well.......
come on guys, knock out two birds with one stone here lol. |
07-23-2008, 11:42 PM | #3 |
I don't think these pills work
Go To Parts Store Rent Steering Wheel Puller And Lock Plate Tool Take Both Off The Remove The 2 Screws Holding The Turn Signal Switch In Place Then The Is 1 Phillips Screw That Holds The Lock Cylinder Once You Remove It The Lock Cylinder Pulls Out New One Goes In The Reverse All Prev. Steps
SQUARE84 90 SUBURBAN |
07-23-2008, 11:59 PM | #4 |
Robert Olson Transport
if you dont want to rent a lock plate tool its easy to make one using a piece of flat stock, a couple of bolts and four nuts
07-24-2008, 12:00 AM | #5 |
07-24-2008, 09:49 AM | #6 |
I'll try to make one..
07-24-2008, 11:28 AM | #7 |
Arrived on a Pale Horse
I borrowed both tools from Autozone and changed it right in thier lot. Then walked right back in and got my deposit $ Back.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
07-24-2008, 03:32 PM | #8 |
doesn't the removal differ some between 73-80 and 81-87 ? i have been told there was some difference. i don't know.
Art 1975 c-10 stepper 1978 single cab dually 1987 crewcab dually 1986 crewcab single wheel 1948 anglia- (the dixie twister super gas) |
07-24-2008, 07:22 PM | #9 |
Crew Cut
the older ones has a pin you push in with a screwdriver in place of the set pin
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
07-24-2008, 07:56 PM | #10 |
thats what i was thinking i have done both if its your 1st time then just be patient its not as hard as it seems. the 1st time i did mine was in my school parking lot at 11;45pm so yea it was a b!tch
07-24-2008, 09:05 PM | #11 |
Help heeeeelp me guys!!!!! I canīt remove the old cylinder check the pic!!!
07-24-2008, 09:40 PM | #12 |
WOW! i just did mine in the autozone parking lot so i wouldn't have to rent the tools and it took me about 15-20 minutes......
i didn't have to take anything out of it. just took off the white turn signal switch and then removed the torx screw that held the cylinder in place and then pulled. it came right out. i have no idea what would be holding it in there......you have the key in the lock position right? |
07-24-2008, 10:01 PM | #13 | |
07-24-2008, 10:10 PM | #14 |
here's a pic of the other side in lock position
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) Last edited by andresco50; 07-24-2008 at 10:11 PM. |
07-24-2008, 10:16 PM | #15 |
ok, the whole where i drew the circle - that is where the torx screw was on mine. when i pulled it out, it was about 3/4 of an inch long and thats what holds it in place. so unless it is broke off in there or something else is in there i dont see what would be holding it in place.
do you have a pic of the actual key hole? maybe you have the pin style.....where you have to push the little pin in then pull. mines an 85 truck with tilt steering btw. |
07-24-2008, 10:28 PM | #16 |
thanks man here's some pics
07-24-2008, 10:56 PM | #17 |
pin hole should bee on the lower outter side (black side) and im pretty sure you need a key to get it out
07-24-2008, 11:16 PM | #18 |
I canīt find it..... maybe I have to drill a hole here
07-25-2008, 12:12 AM | #19 |
If you removed the correct screw , try turning the ignition to the run position and see if it comes out . I cant see but if there is a slot where my arrow is , Take a screwdriver and press the small latch where the arrow is pointing if there is a vertical opening . If it doesnt come out the first time , turn the key to run and try again . The torx screw should have had a threaded portion and a smooth shouldered section if it was the correct screw .
Frank
Born and proudly residing in a Red State ! Last edited by f.monroe; 07-25-2008 at 12:14 AM. |
07-25-2008, 12:28 AM | #20 |
thats how mine was (torx screw) and thats all it took and the key cylinder basically fell out in my hands.
i bet his is the one you have to use the screwdriver to get out with. i've never seen that one personally so i dont know the how to for that one. |
07-25-2008, 12:38 AM | #21 | |
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) Last edited by andresco50; 07-25-2008 at 12:41 AM. |
