Old 07-24-2008, 01:57 AM   #1
67chevyguy
67chevyguy's Avatar
what year ps pump?
hey all,
I was hoping some one could tell me what year power steering set-up I have.
The vin on the cab says 1967 but someone told me that my frame must be a 1968 due to the indent for the steering box?
another question, is the pump in the reservoir or is that the pump in the steering box?
last question, what would you call the seal where I have the arrow pointing? I'm leaking pretty bad there, does the steering box need to be pulled right apart or can the seal be changed easily?
67chevyguy is offline   Reply With Quote
Old 07-24-2008, 08:06 AM   #2
JimKshortstep4x4
Re: what year ps pump?
The pump pictured with the silver brackets is from a later model. The brackets look like they are off of a van.
You will want to pull the steering box as you will need room to work on it to replace the seals. I believe NAPA still has seals for the box.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-24-2008, 09:41 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that would be the input seal.
The pump is in the reservoir
look at the numbers on your frame, that'll tell you if it belongs to the cab or not.
You can see them just a little in this pic;
Old 07-24-2008, 10:47 AM   #4
67chevyguy
67chevyguy's Avatar
ok, thanks guys, my questions are answered
*edit*
new question: any ideas what year of van the pump might be from then?
or any other pumps that will work with my bracket and steering box.
Thanks a bunch.
Old 07-24-2008, 10:19 PM   #5
67chevyguy
67chevyguy's Avatar
bump*
Old 07-24-2008, 10:31 PM   #6
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Is that a long water pump? I've had several people locally tell me that every 67 they've seen had the extra dimple in the frame. Go figure!
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 07-24-2008, 11:43 PM   #7
67chevyguy
67chevyguy's Avatar
it's a long water pump
as a side note for longhornman
I can't make sense of the VIN on the frame
The cabs VIN is CE1471117722 which works out to 1/2 ton v8 1967 oshawa
The number on the frame above the steering box is CZ171540 which doesn't make sense based on the vin decoder on this site
Old 07-25-2008, 07:47 AM   #8
mrein3
mrein3's Avatar
It makes total sense. Somebody put a different cab on that frame. The last 6 digits of the frame should match the last 6 digits of the cab.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-25-2008, 11:09 AM   #9
clay68c10
clay68c10's Avatar
The internals of the pump are the same for about a 20 year timespan. The only differences are the reservoir housing, hi-pressure outlet valve fitting, and the pulley type.
Looking at your reservoir, I'd say it's something from the 70's.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-25-2008, 03:20 PM   #10
Shyguy
Junior Member
Shyguy's Avatar
I have a stock '67 C-20 and it does not have a dimple on the frame for the power steering box.
My son's '67 C-10 had power steering but did not have the dimple on the frame, he had the ram assist type power steering.
My '67 C-10 short stepper has the dimple on the frame, but the frame is a '69.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 07-25-2008, 10:59 PM   #11
67chevyguy
67chevyguy's Avatar
ok, I think I get it. So the VIN on the frame will only have the production number where as the cab has the chassis, engine etc. codes and production number. That would explain why I couldn't decifer the VIN on the frame. Sorry noob here
thanks everybody
Old 07-25-2008, 11:20 PM   #12
Classic Bowties
Always on the hunt...
Just a note: I have personally seen/verified several factory 67 C series frames with the clearance dimple for a ps box, first year for K series ps & dimpled frame was 69.
Classic Bowties is offline   Reply With Quote
