Old 07-24-2008, 11:31 AM   #1
yfz450_0569
Parallel 4-link questions
I'm planning on running a parallel 4-link with the frame I'm building for my truck. The frame rails are 30 inches to the outside and 26 on the inside. This leaves about 21 inches from the outside of the frame rails to the bedside on each side. Right now I'm gonna run about a 10 inch wide tire, but I want to be able to run a wider tire, maybe a 15 inche wide tire in the future. How could I set this up for it to work, I still want good cornering, don't know if it would work putting the bags between the rail or right under the rails.
yfz450_0569 is offline   Reply With Quote
Old 07-24-2008, 12:13 PM   #2
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Re: Parallel 4-link questions
It sounds as though you're building a one-off custom that will lay frame on bags-no? If that's the case you may want to consider a bad-a$$ IRS setup like is shown in the link. They're available with coil overs or bags for that layed-out look.
http://www.kugelkomponents.com/produ...uspension.html
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 07-24-2008, 12:34 PM   #3
yfz450_0569
I don't think I want an IRS. I would like to know though if the 4-link bars need to be run on the outside of the frame, I would think so and same for the bags?
Old 07-24-2008, 01:09 PM   #4
lowriden58
lowriden58's Avatar
IMO it would be best to run a triangulated 4link with bags on bars for a softer ride and better handling and there will be no need for a panhard bar with that setup vs with a parallel setup.
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 07-24-2008, 01:39 PM   #5
yfz450_0569
I was told I should go with the parallel running 500 to 600 hp... maybe I'll design a watts link if I don't go with the panhard bar.
Old 07-24-2008, 01:39 PM   #6
cdowns
cdowns's Avatar
the further outboard the links are the smoother the suspension will be
Old 07-24-2008, 01:43 PM   #7
yfz450_0569
Sounds like I'll just be able to fit these wheels or change it all to a triangulated 4-link
Old 07-24-2008, 03:25 PM   #8
jd4300fel
jd4300fel's Avatar
there is a program on extreme4x4from spike tv tha you can use to figure out the geometry
Mike K
Friend of Bill W
jd4300fel is offline   Reply With Quote
