Old 07-24-2008, 03:45 PM   #1
PHOENIX
Electrical problem?
I'm losing electrical and the engine is shutting off.
When this happens I have headlights, but no ignition power, no instrument power, no turn signals, & no heater power.
At first I thought it was my old alarm system. As sometimes it would just start going off while I was driving. I removed the alarm system and it didn't solve the problem. Then out of nowhere it started working again. So I'm thinking lose connection or bad component somewhere. I checked all the wires the alarm was attached to and everything seems good.
Well yesterday I was driving down the street about 45-50mph. The engine died, not sure if the instruments (gauges) went dead or not. I pulled off the road and figured I'd be getting a tow truck. I turned everything off and turned the key. It started right up and I went on my way.
Could a bad ignition switch cause this?
Bad ground wire somewhere?
Distributor (its an MSD, a few years old)?
What to look for, where to start?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 07-24-2008, 05:15 PM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: Electrical problem?
I had this problem and it turned out to be the ignition. Do you have tilt wheel steering, does it feel loose? Well on mine it was loose and kept grounding out the ignition. I removed the steering wheel and backing plate and retightened the hex head bolts holding the tilt couple together, fixed the problem. Hope this helps.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 07-24-2008, 05:22 PM   #3
PHOENIX
No tilt steering wheel. My truck is seriously lacking options.
I doesn't even have A/C!
My gut feeling is ignition switch. Are they easy to replace?
Old 07-24-2008, 10:41 PM   #4
PHOENIX
Is there any way to test the ignition switch?
Old 07-25-2008, 10:50 AM   #5
Eyegore
What Hump?
Eyegore's Avatar
I don't know of a way to test but it depends on your own ability as to whether it is easy or not. You have to remove the steering wheel, then the plate behind the wheel (you have to remove a lock ring and someties takes a speacil tool) then the signal mechanism is exposed. You then unscrew it from the column, unplug the harness from the overall harness, feed the signal harness up through the column, installation is oposite of removal.
I suggest you head over to the wrecking yard to look at some already apart. Ecology on 27 Ave & Harrison (downtown phx) had several trucks apart, you may even want to pickup a tilt a install it, but thats a different procedure.
Hope you find the problem.
Lil red 86 c-10
99 Sub
Old 07-28-2008, 12:25 PM   #6
PHOENIX
Thanks for the help Eyegore.
I don't know what years are different, but my '83 has the ignition switch on top of the column, behind the gauges.
Here is what i had to do:
  1. disconnect the battery
  2. put key in off position
  3. remove the gauge cluster
  4. unplug and remove the neutral safety switch (for manual transmission)
  5. remove the two column clamp nuts (15mm) at firewall in engine compartment
  6. remove the two column nuts (15mm) behind gauge cluster
  7. support column from top of dash framing with some cable ties
  8. unplug wire harness from ignition switch
  9. remove two ignition switch screws (5/16")
  10. make sure new ignition switch is in the off position
  11. place new switch over actuating rod
  12. assembly is reverse
I still don't know if this is my problem, but I figured its likely and the part is only $25 (ECHIN, from Napa). Its a USA made switch.
I disassembled (ripped apart) the old switch. I couldn't tell for sure is the switch was bad. It did appear worn and some black around one of the contacts.
Hopefully its fixed
EDIT (Aug. 1, 08): Well its not fixed.
http://67-72chevytrucks.com/vboard/s...d.php?t=301501
Old 07-28-2008, 10:27 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
what i would do too for added measure is to wiggle the wires where they go into the firewall and make sure the connection is tight.. also check all the other connections you see but from what you describe im kinda thinking ignition switch myself..
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
