Some Lowering Questions
If I get 3" lowering springs in front and 2" lowering drop schackles in rear, will I need anything else for my suspension?
Should I upgrade the shocks as well?? Also, When you buy dropped shackles do you usually get a set for both leafs, drvrs/psngr side? or just on side only. Is going with a dropped spindle better than lowering with coil springs, or is the only difference that by using lower springs the ride can be a little stiffer? Last edited by GMC65Guy; 07-24-2008 at 05:47 PM. |
Re: Some Lowering Questions
too much lowering with springs causes problems with front end geometry, spindles don't change the geometry.
your current shocks might bottom out, not sure you should get shackles in pairs
#3 | |
How hard is it to install spindles? |
shackles are just at the rear of the spring, so there is one per side, you get 2 and it does both sides.
spindles are just remove the brakes (depends on which you have, drums or discs) take the tie rod loose and disconnect the ball joints, pretty easy
#5 | |
ah... ok thanks! |
Cantankerous Geezer
Using the drop spindles is the way to go. It is also a good time to put on some disc brakes.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
The only problem with that is... I can go with spindles.. get 5lug disk brakes up front..then i need 5 lugs in rear conversion..then ill need a different booster so Ill go power... and thats wayyyy to much money for me now. I just want a quick easy lowering job.
I cut my coils on the front for a quick, dirty, and cheap(free) lowering, it isn't any harder than changing spindles, then later on when you get more money for the project, you can get all the goodies
you can also get 6 lug discs to fit your lowering spindles, and not have to change the rear. oh and also you can run discs with out power brakes, just food for thought ![]()
![]() ![]() Last edited by joe231; 07-24-2008 at 09:08 PM. |
#9 | |
Will I have to buy a new booster/get a porportioning valve? Or can I use my stock single line mastercylinder? Last edited by GMC65Guy; 07-24-2008 at 09:23 PM. |
KOFFIN DRAGGER
I would upgrade to at least stock power brakes and a 2 chamber master. You will need a prop valve because the disc brakes only need like 2lbs and the drums need 10lbs. My discs were not quite a bolt in, but very close. I had to replumb the front brakes for the 2 chamber master cylinder and change the hoses to a banjo style fitting for the calipers.
If the life I live dont kill me, then I guess I'll never die! New updated stuff at www.kdrodworks.com My site still needs help, web guys and gals pm me. the best guys in the whole world: sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231 |
definitely swap to a dual master, but you can run one with out power, I do not know which one you would need, but as KD said you will need new lines. go check out a salvage, I'm sure you could find a master booster combo that could be adapted fairly easy
#12 | |
Council of the Elders
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times Last edited by billydonn; 07-28-2008 at 10:45 PM. |
#13 |
