11-12-2002, 08:34 PM | #1 |
Frame chopping?
I am going to cut a 72 long bed 4x4 frame to short bed specs. Anyone have any details as far as how to go about it? I am a capable welder and have a good mig and plasma cutter to work with. Would also like to know the exact amount on how much I need to shorten the frame between the front and rear axles. Also what about the rear of the frame? Thanks for any info you share.
11-12-2002, 08:40 PM | #2 |
Fabricate till you "puke"
12" out of the middle, & 8" off the butt.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-12-2002, 09:12 PM | #3 |
aka Crusher, Crushergmc
PM efabman, He did this to a 2wd and did really nice work. The "z" in the frame was right as rain. Good luck.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
11-12-2002, 09:36 PM | #4 |
Yea, I should have done a search first before posting this. I looked at his work and it was first rate. Thanks!
