Drive Shaft Measurements
When measuring for a one piece drive shaft do you measure from the end of the tail shaft to the center of the yoke or the flanges that the u-joints bolt to?
Bill Durham http://home.attbi.com/~bulldurham 72 Cheyenne Restoration in progress Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed. |
14.1 @ 96MPH
IIRC, the shop I went to (Dick's Driveshaft in Phoenix) wanted the measurement from the seal of the tranny to the center of the U-joint on the rearend. Call up where you're getting it from and ask how they want it...
(here is the shop's page describing measurements...)
Project1970 - LS1 Swap Complete! ![]() |
Fabricate till you "puke"
Slide the bare slip yolk in the trans till it bottoms, then pull it back out 3/4 ". Measure center to center on the caps, thats the dimention the shop needs to set you up. good luck....69
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
