Old 05-08-2002, 01:35 PM   #1
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
Post Decoding and building suggestions please!
Ok guys i went and bought that 350. I can sorta distinguish the casting but the last digits are blurred. the first are 397 but the rest i cant make out well, seems like it might be some zeros or something but the casting blew. Anyways the head number on these is 462624 and i measured a few of the valves. They were what looked like 1.9/1.5.
The block is from general inspection about 4.040" bore and the pistons in it are slightly dished. The guy i bought it all from said he thinsk the motor was bored 40 over and that he thinks it has a steel crank.
A few of the valves on one head are burned and the motor has been sitting for like 15 years. It came out of a 70's step-van or something like that i was told.
This will be my new long term project/learning toy as i've never rebuilt am motor. The rockers look good and he gave me the old pushrods. I'll have to take off the timing cover and oil pan to see more stuff. Thanks for the help guys, i'll keep ya'll posted. Ohh FYI i paid 80 for it all.
69 Custom 20, 396BB,Longbed fleetside.
New Oak Bed With SS strips... damn nice.
Edelbrock performer RPM-O, Edelbrock 750Carb, Headers, HEI, 2 40" glasspacks.
Stereo: Classic-style tape deck/radio, 2 6x9 Cerwin Vega's in doors, 2 10" Neo subs under seats, 1 900 Watt amp.
SN= Ares220
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 05-08-2002, 01:51 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
the block is probably 3970010 or 014
the heads are scrap get rid of them now before they ruin your bottom end, 624 are the worstheads out of all the heads GM ever made, 882 are second worst., lots of cracks and very cheap thin wall casting they are, unfortunately both castings are very common, i scrapped 4 sets of 882 last fall and a couple 624 and found a set on the 85 350 that i removed and am scrapping too after i rob the pipe plug and temp sender off them
good luck
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase, #1
-90 Cavalier 2.2L sky blue, a driver
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2
-82 purple Trans Am, project #3
*Paint is overrated*
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 05-08-2002, 06:27 PM   #3
Big69C20 Toy
Livin' it up.
Post
Thanks Randy, any building suggestions? i'm trying to stay cheap as possible. this motor might go in my truck once it's done so that i can pull my BB and work on it
Perphaps a stroker? i know lots of guys out there have em. Thanks
SN= Ares220
-Greg;
Old 05-08-2002, 08:40 PM   #4
Randy70C-10
Randy70C-10's Avatar
Post
If you bore again, .060 stroker (400 crank) will make it a 388. I'd just hone the cylinders and have the crank turned (provided it hasn't been turned before). Some people go .020 under on the crank, but I personally wouldn't go more than .010. You can tell if you have a steel crank by looking at it. A cast one will have mold lines in it. Change those heads!!!! Vortec seem to be the way to go.
Yeah, that's right. My name is Randy too!
WWW.Randysrods.freeservers.com
1970 Chevy C-10 shortstep
30 Ford Model A Coupe 4 inch chop, 350, GMC 671 blower-Hell yeah it's fast!
87 Harley Sportster(couldnt get a 350 to fit)
Self Propelled Lawn Mower
Built in USA!!!!
Virginia Beach, VA.
Randy70C-10 is offline   Reply With Quote
Old 05-08-2002, 09:08 PM   #5
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
Post
Sort of on topic, sort of off: When did Chevy start scalloping the outboard edge? My '78 624s have that edge (and they both had at least one crack running through that edge as well as a crack through the center steam holes), but my '69 882s don't.
I say '69 because their straight outboard edge is supposed to designate an earlier, thicker (ergo stronger) casting (so said my instructor & my machinist). I do know those heads were a few pounds heavier than my 624s (I weighed them as bare castings fresh from the hot tank).
67 C20 '78 400sb 0.030" over, 9:1 cr, CC Xtreme 4x4 254H, port-matched '69 882 heads & stock cast iron intake, rebuilt Q-jet, Summit headers (1 5/8" primaries), true dual 2 1/2" glasspacked exhaust, NP435CR trans, 4.57 Eaton rear end.
It's a decent-looking work truck. No top-end, but it's great off the line.
'69 International Loadstar 1700 school bus converted to an RV. Working p/s (only took three years and three owners to replace the belt & a pressure line), low-compression 345 (176 certified net hp @ 3800rpm), single 3" exhaust w/custom cherry bomb muffler, NP435 trans, two-speed Eaton rear end, very warm & rodent-free heaters.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 05-08-2002, 10:16 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I wish I could remember who sent me this...it was someone on this board.
Some of the 882's are not too bad acording to this. I had been told in the past that there were some 882's worth looking for, I guess this kinda shows which ones.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-08-2002, 10:56 PM   #7
bigvinnie
bigvinnie's Avatar
Post
Longhornmail, so to ID the inferior 882 head externally, the exhaust manifold bosses on the driver front and passenger rear would be longer and have an extra hole that would be visible when using stock ramhorns, correct? Thanks for the clarification.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
http://www.ixpres.com/vlusardi/chevtrk.htm
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 05-08-2002, 11:54 PM   #8
Longhorn Man
Post
I just look at the shape by the plugs...
Columbus Ohio
Old 05-09-2002, 10:38 AM   #9
Blue68
Blue68's Avatar
Post
As far as machine work is concerned (assuming you are going that direction), let your machine shop do all your measuring and recommending on tolerances. Since you are going to possibly put it back in your truck, go with the Vortech heads (new assemblies from most dealers, I like Sallee-Chevrolet.com). I went with a Comp Cams Extreme 4x4 camshaft (but then I have a roller block), for the low end torque and decent HP (similar setup rates 350hp@5100 and 390lb/ft@3800 (368lb/ft@3000).
Check it out... http://www.sallee-chevrolet.com/Chev...e_4x4_350.html
Mainly, make sure your parts make a package. And make sure the package matches the intended target platform and use.
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, GM HEI, CompCam Extreme 4x4, Thorley Headers, 700r4, 3.73, disc brakes and power steering upgrades.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
