Another Drive Shaft Question
When I put the BB in, the tranny sits about 1 1/8" forward than when I had the SB in it. Is that too much of a difference to use the same drive shaft or should I put in a longer one?
Bill Durham http://home.attbi.com/~bulldurham 72 Cheyenne Restoration in progress Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed. |
14.1 @ 96MPH
It depends on how far in the yoke was to begin with. My guess is you're gonna just barely need to get it lengthened, unless it was on the long side before...
Project1970 - LS1 Swap Complete! ![]() |
