http://public.fotki.com/street
Does a 71 have a proportioning valve
I am converting my 64 over to a manual front disc set up from a 71. I am using master cyl etc. The truck I got it from didnt seem to have a proportioning valve for the dic set up. Did they use one in 71 ????
it should have one. sounds like someone did some hacking. i dont know why anyone would remove the prop valve
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
![]() Join Date: Feb 2001
Yes, 71 has a proportioning valve. I have converted a few '66 trucks to front disc and used the '66 master cylinder with no p.v.
Yes. And No. Starting in 1970 or 1971 GM went from the distribution block with a separate proportioning valve to what they called a combination valve in their cars. Trucks should all have the Combi. Valve. This valve is right below the master and incorporates residual pressure valves if required and f/r brake bias in addition to the fluid circuit switch that triggers the light on the dash. This is longer than the distribution block you would find on a drum brake truck. On 71-72 it has two lines coming out, 1 for front and 1 for rear. On 73 and up trucks it has 3 outlets, one each for front and the rear. (I used one of these with a plug in one of the fronts for my disc conversion.)
