07-25-2008, 04:07 AM | #1 |
Which Mustang II IFS?
Hi, I just bought a 50 Chevy 3100. I am getting ready to start the build and I am getting my parts list together. I have been looking at the differrent brands of IFS setups and wondered what you all recommend? Should I go with manual rack & pinion or power? Stock or 2" drop? I don't want to run bags.
I will be running a four link rear setup with coil overs. Thanks for your advice, Renegade |
07-25-2008, 07:15 AM | #2 |
Yellow truck club
Re: Which Mustang II IFS?
Welcome to the site. Lots of info here for your ride to be. If you do a quick search there has been lots of info and opinions on types of MII setups on this forum.
PS we like pictures......
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited Last edited by entourageguy; 07-25-2008 at 07:16 AM. |
07-25-2008, 06:48 PM | #3 |
Have you looked at Industrial Chassis Inc, Steve makes a crossmember for the A D trucks that uses 86 to 90 Dodge Dakota bolt on parts and they use a power Rack and Pinion the best part is this is a suspension from a truck about the same weight as our AD's. These parts fit like a glove with very little grinding and they come with the boxing plates as part of the crossmember.
The GMC that I am driving now has a Mll so this one I am going to use the Dakota it is for a 53 Chevy
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
07-26-2008, 04:54 PM | #4 |
I like fatmans, check out my build thread below in the signature. It should help you out.
Josh
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
07-26-2008, 10:57 PM | #5 |
I have a scotts. Its really nice.
07-27-2008, 05:05 PM | #6 |
BIG CHEVY 3600 LONGBOX
I have Heidts IFS with a 2" drop and power rack. It is probably the most expensive IFS but touted to be the best. I won't be trying it out for another 2 or 3 months (praying) so cannot testify as to how well it works yet.
http://www.heidts.com/index.cfm/page...=cat/cat82.htm
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
07-28-2008, 08:06 AM | #7 |
TCI & heidts look the same when put side by side...buy the cheaper of the two.
Don Meyer |
07-31-2008, 07:55 PM | #8 |
After reading your suggestions, I am leaning toward the Heidts. I really like the way they are set up. I also talked to one of the top rod shops in my area and they use Heidts 8 out of 10 times over the other popular brands.
Thanks for your help, Renegade |
08-02-2008, 01:02 PM | #9 |
J.W. Rod Garage
08-02-2008, 02:53 PM | #10 |
I've got a new set of upper and lower control arms from Heidts that I'm selling cheap...
http://67-72chevytrucks.com/vboard/s...d.php?t=260891 LMK, R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
