Old 07-25-2008, 04:22 AM   #1
layinlow69
bagging a 69 c-10
does anybody know if there is a way to lay out the front without buying a dropmember if so what does it take. Any help would be great thanks
layinlow69 is offline   Reply With Quote
Old 07-25-2008, 09:30 AM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: bagging a 69 c-10
bags, drop spindles and modified a-arms.
just with bags and drop spindles your cross member will be about 1.5" off the ground. you'll probably also want to section your cross member too.
you could also go the route of Z'ing your frame.
IvelDesigns is offline   Reply With Quote
Old 07-25-2008, 02:49 PM   #3
layinlow69
How do u z a frame where do u cut
Old 07-25-2008, 03:41 PM   #4
powell72
powell72's Avatar
Your best bet for info is to browse the suspension forum here-
http://67-72chevytrucks.com/vboard/f...aysprune=&f=25
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 07-25-2008, 03:49 PM   #5
IvelDesigns
quite honestly, and i don't mean this as a jab, but if your fab skills aren't top notch, you're probably better off buying the drop member.
there are a lot of things that have to be taken into account when doing a proper Z, whereas a DM is pretty much bolt on.
definitely take some time and read the suspension forums. All of your questions, and then some will be answered there.
