Old 07-25-2008, 07:44 AM   #1
ajserra
Newbee
Hi guys, I just joined the group and was interested in seeing if anyone can help me out. I have a '69 C20 longbed with a big block and a turbo 350 .There is a grommet/plug missing from my firewall that is allowing heat and fumes into the cab. It is about 2 inches in diameter (Oval shaped) and is located right behind the exhaust manifold on the drivers side. Someone suggested that it might be where a shifter rod or a 4X4 rod would go through if the truck was equipped that way. I don't know so I'm trying to ask you guy's to help me identify what it is called, a gm part # if possible, if it might be available in repro, or if someone has one on a parts truck that they would be willing to part with.
Any help would be appreciated. You can e-mail me at ajserra@hotmail.com
ajserra is offline   Reply With Quote
Old 07-25-2008, 09:05 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Newbee
sounds like the cut out for the clutch hole.....you may need a clutch delete plate.....check out this picture (may not look exactly like your firewall)....you may want to PM 'teeitup' to see if he has any left....Good luck and I hope this helps....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-25-2008, 09:07 AM   #3
Luvlegs
Luvlegs's Avatar
Re: Newbee
sounds like a clutch delete plate - do a search in the parts section, there's been a few listed lately and Welcome to the board!
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 07-25-2008, 09:08 AM   #4
lowriden58
lowriden58's Avatar
Re: Newbee
Welcome from MD!
That would be the shifter linkage cover not sure if anyone makes a repro, but do a search in the parts section. i know someone was selling a bunch of them not long ago
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 07-25-2008, 09:10 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Re: Newbee
That would be the hole for the clutch rod. There are a couple of different covers for it, one being a plastic plug and the other being a metal plate held on with a small screw at the top & bottom. I think the metal plate is more common but the plastic plug is easier to install if your firewall doesn't have the screw holes already in it. I will see if I can find a pic.
http://67-72chevytrucks.com/vboard/a...1&d=1205842691
Just as a heads up it is against board rules to post a "wanted to buy" unless you are a subscriber ($25 yearly) but you can go to the parts board and if you find one for sale you can buy it..
LockDoc
Leon
Old 07-25-2008, 11:09 AM   #6
2nd_wnd
2nd_wnd's Avatar
Re: Newbee
Whats one worth, i picked up a scrap truck the other day that had one installed on it
72 LWB
2nd_wnd is offline   Reply With Quote
Old 07-25-2008, 01:49 PM   #7
LockDoc
LockDoc's Avatar
Re: Newbee
I guess anywhere from 5-10 bucks depending on shape. They aren't too hard to find....
LockDoc
Leon
