Old 07-25-2008, 01:31 PM   #1
rick0312
rick0312's Avatar
rear motor mounts?
I can't figure out how these mount. I think I might have the wrong mounts. Any advice?.....thanks
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 07-25-2008, 01:40 PM   #2
71 super
71 super's Avatar
Re: rear motor mounts?
they are the supports for the bell housing on straight drive 2wd truck. They are the only mounts on the three speed trans/four speed trans. The piece you showed first goes on top of the cross member and the small piece goes on the bottom and is held in place w/bolt and a three eared lock washer type thing.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 07-25-2008, 03:35 PM   #3
rick0312
rick0312's Avatar
they won't fit through the holes on the crossmember. i have the poly bushings.
Old 07-25-2008, 04:09 PM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
The bigger block should saddle the cross member and the little one comes from under with the bolt
sneakysnake is offline   Reply With Quote
Old 07-25-2008, 04:16 PM   #5
rick0312
rick0312's Avatar
the center part of the mount is too large for the crossmember holes.......cheap made in china crap!.i paid 50 bucks for these mounts! they are going back.
Old 07-25-2008, 04:55 PM   #6
rick0312
rick0312's Avatar
anybody experience the same problem?
Old 07-25-2008, 06:48 PM   #7
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Whips out Hammer And Drill. They Will Fit
But in all seriousness that Stinks maybe for a diff year/ wieght class/
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 07-25-2008, 08:18 PM   #8
kwmech
Betcha they sent you the ones for a 4x4 and not the 2wd bellhousing mount
kwmech is online now   Reply With Quote
Old 07-26-2008, 12:06 AM   #9
rick0312
rick0312's Avatar
they are about a 1/8" larger......I was thinking about drilling the holes bigger, but I wouldn't want to throw the tranny and drive shaft allignment off.
Old 08-03-2008, 12:57 AM   #10
rick0312
rick0312's Avatar
kwmech you were right.....they sent me the 4x4's......thanks for the tip.
