Old 11-12-2002, 09:25 PM   #1
Larry68GMC
HELP...Broken Intake Bolt
I was swapping Intakes and went to take old one off, put socket on the bolt, started taking loose and the head snapped off. I have about 1/4 inch of bolt sticking out. I tried vise grips and that didn't budge it. Any other ideas? Thanks
71 GMC LWB 350, Dart Pro1's 200/64cc,10.2:1
RPM AirGap, 224/234 @50 496/518 lift w/1.6 roller rockers, 2500 stall
'05 Dodge 2500 Crew Cab 4x4, 4 inch lift and 35's CTD
Larry68GMC is offline   Reply With Quote
Old 11-12-2002, 09:32 PM   #2
WORNBRAKES
You could try some penatrating oil or try heating it up. If that don't work, Get a set of easy outs. You can buy just the particular size you need or buy a set. They are very handy.
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 11-12-2002, 09:36 PM   #3
cableguy0
go get a can of pb blaster very very good stuff makes wd40 look terrible. soak it down then try the vise grips again. or go get urself a stud remover socket. u could also try a left handed drill bit
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-12-2002, 09:53 PM   #4
Piston
Piston's Avatar
PB Blaster!, that with a little heat should get it moving again.
There haven't been to many GM's I haven't removed using that method. Mainly because the bolts that break are 1 of the 4 near the thermostat and seize from the coolant corrosion. PB will cut right through that type of corrosion. the heat will make it work a bit faster while expanding the head slightly.
basicly do what cableguy recommended and add heat. (just a small propane bottle will do)
Piston is offline   Reply With Quote
Old 11-12-2002, 10:27 PM   #5
jasonrog
jasonrog's Avatar
What is PB?
jasonrog is offline   Reply With Quote
Old 11-12-2002, 10:28 PM   #6
Piston
Piston's Avatar
http://www.pbblaster.com
Old 11-12-2002, 10:30 PM   #7
cableguy0
pb blaster is an excellent penetrating lube that is by far better than almost anythign else out there. i havent found anything thats better . i know that stuff has saved me hours of fighting with bolts. stuff that i let soak in wd40 for days and still wouldnt come loos pb blaster had it free in 10 minutes or so and thats not exxageration
Old 11-12-2002, 10:31 PM   #8
cableguy0
d@mn piston ya beat me to it
Old 11-12-2002, 10:32 PM   #9
Piston
Piston's Avatar
lol I picked the lazy way...
Old 11-13-2002, 12:17 AM   #10
jasonrog
jasonrog's Avatar
Where can I buy this in Canada?
Old 11-13-2002, 12:21 AM   #11
cableguy0
have no clue about canada but here in america every auto parts store known carries it
Old 11-13-2002, 01:03 AM   #12
Larry68GMC
Thanks guys I will go get me some pb blaster in the morning. Piston got it the broken bolt is the first one on the passenger side.
Old 11-13-2002, 10:54 PM   #13
Larry68GMC
Thanks for all the help. The PB Blaster worked like a champ. Now I can finish swapping my intake. Thanks again guys.
Old 11-14-2002, 01:58 AM   #14
Fast68Chevy
Fast68Chevy's Avatar
cept for auto zone, at least around here anyways
PB is the way to go, NAPA stores have the stuff, use it pretty much everyday
around 4 bucks a can,
WD40 is same as using water
Fast68Chevy is offline   Reply With Quote
Old 11-14-2002, 08:31 AM   #15
Ed ke6bnl
I agree it is the best I get it at Wal Mart . May need to lay a nut over the bolt and weld it to it to turn it out . Ed ke6bnl So. Calif
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 11-14-2002, 01:44 PM   #16
Jmac05
L.E.D. Tail lights, Baby!
Jmac05's Avatar
EZ-outs
IF you get an easy out, and use it:
DON"T BREAK IT!!!
YOu think the bolts are tough to get out...
Ezouts become an oxymoron if you break them.
Prov 3:5-8
"Hook 'em"
L.E.D. Taillights for sale NOW!!!
If interested, visit:
www.earlyclassic.com
or our website:
www.jmcled.com
All 67-72 GM Taillights are on sale untill 5 p.m. on Dec
15th, with Guaranteed Christmas delivery!
joel.mcwaters@jmcled.com
Jmac05 is offline   Reply With Quote
