Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-25-2008, 04:09 PM   #1
Couch
Daily Driver
Couch's Avatar
Drum brake promlem
ok, first off I ordered some custom rallyes from wheel vintiques(12x15) with an 8.5 inch backspacing so I can still run my stock width 12bolt. The problem now having is my 5x5 drum with the fins on it are to bag arond to fit inside my wheel, but my old original 6 lug drum that doesn't have the fins fits perfect.so does any1 know of a drum that will fit or should I bring off the fins on my 5 lug drums or drill my 6 lug ones to fit 5 lug axles?any help is greatly appreciated, thanks guys
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 11-03-2011, 09:38 PM   #2
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Re: Drum brake promlem
I'm havin the same problem on a set of 12" aluminum wheels
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 11-05-2011, 09:57 AM   #3
Camaro_nut2001
I went to my parts store yesterday & had my buddy cross reference these drums & we came up with a '72 Impala drum. It depends on your shoe size but they will interchange & the outside fins are quite a bit smaller. Just thought i'd post in case someone else was havin this problem. I just cut a little off with my grinder on my drums so they would fit in the wheel.
