Old 07-25-2008, 09:45 PM   #1
superchevy
Got big-block?
superchevy's Avatar
700r4 adapter for transfer case....need help
Ok guys. I bought the '72 K20 a few months back. The PO had installed a 454 and 700r4 in front of the NP205. The 700r4 shifted great, but I want to install a 4L80e because I plan on doing a lot of towing with this rig.
After doing some research, it looks like I'm going to go with an Advanced Adapters kit. Anybody have an idea on the make of the adapter?
Thanks,
Casey
You have to be a subscribing member to post "what is it worth?" or "for sale" ads.
Please consider supporting the board by subscribing.
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 07-26-2008, 08:48 AM   #2
LONGHAIR
Re: 700r4 adapter for transfer case....need help
Why not just keep the one you have? The 700r4 and the L480e are very similar. Aren't they basically the same externally? The adaptor you have should work....
Are you aware of the electronics required to run the L480e?
LONGHAIR is offline   Reply With Quote
Old 07-26-2008, 10:24 AM   #3
FormerMember
700R4 = 4L60(e)
4L80E is the bigger brother.
Looks like you have a 2wd 700R4 there that someone created a spacer to get the correct input depth on the t-case. Got pics of the t-case and adapter?
I'd say home made there.
Now my question: Why go with AA, when you can get a stock adapter that will do the job?
Also, you know the 205 you have now is 27 spline and the 4L80E will be 32 spline?
(let me know if you need pictures, I have all of the parts sitting in my garage)
FormerMember is offline   Reply With Quote
Old 07-26-2008, 01:36 PM   #4
superchevy
Got big-block?
superchevy's Avatar
Home made? It sure is a nice piece for home made.
The output shaft on the 700r4 has definitely been cut down as the cut is not exactly square.
Grendel, I've followed many of your post concerning the 4L80e swap, so, yes, I know the NP205 is 27 spline...and yes, I know the 4L80e is 32 spline...and yes, the Advanced Adapter kit does not include the 32 "full spline" output shaft I'll have to install...and yes, I would love to use the rare factory adapter...can you give me a source for it? Here are some of the pics.
Casey
build thread
build thread
Old 07-26-2008, 02:06 PM   #5
FormerMember
Casey
I have three of those adapters in my garage. They're not super rare. Also, 4L80E's can be found with full splines to get complete engagements. I have two of them. They're a 4wd trans, from 91-95.
I say home made because someone adapted an early model 205 (male input) to a 700R4. It looks like they cut a late model adapter to make the spacer, then used the 205 adapter and clamped it together. They probably needed some length in the adapters to allow for the coupling sleeve.
Old 07-26-2008, 02:20 PM   #6
FormerMember
This adapter will bolt that t-case to a 4L80E
http://cgi.ebay.com/ebaymotors/_Car-...em270257808085
I'd swap the input on your 205 to a 32 spline female and call it good.
Old 07-26-2008, 02:42 PM   #7
b454rat
The 400/205 adaptor will work, but the ID is different between the two, where the adaptor bolts to the tranny. It's a couple thousands off, can't remember the exact amount, but don't see why you couldn't trim it to fit.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 07-26-2008, 02:44 PM   #8
superchevy
Got big-block?
superchevy's Avatar
Hi Grendel...thanks for the input. This is a confusing subject to a 4x4 newby like me...I've tried to get the right info from previous posts, but obviously missed some points.
I have a '94 4L80e out of a 2wd truck. From what you've suggested, I need the factory T400/NP205 adapter and change my 205 to a female 32 spline input?
Thanks,
Casey
build thread
build thread
Old 07-26-2008, 02:47 PM   #9
superchevy
Got big-block?
superchevy's Avatar
b454rat,
I think I read that somewhere as well. Thanks for the tip.
Casey
build thread
build thread
Old 07-26-2008, 04:11 PM   #10
FormerMember
Thanks,
Casey
You will also need to cut down the output shaft on the transmission.
Then again you'll also need a trans controller. I plan to use a factory one, 91-93 Diesel 3/4 ton
Old 07-27-2008, 03:20 PM   #11
OldCreek
OldCreek's Avatar
try this:
http://67-72chevytrucks.com/vboard/s...hlight=adapter
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
