Old 07-26-2008, 01:59 AM   #1
ripdog28
ripdog28's Avatar
Sway bar
So i got a kit from Performance Online and the truck is sitting on the suspension without an Engine. The sway bar is 1" to long on both sides. Should i wait for the Eng to be installed?
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 07-26-2008, 02:12 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Sway bar
I'm a little confused. I checked ECE's site and the sway bar they list doesn't look like this one. They show a stock style but 1 1/4" thick instead of the factory 1 1/16". Looking at your lower arms, the two mounting holes on the plate in front of the springs is where the stock mounts go. Stock setup does not use sway bar links like what you have on yours.
Kind of weird but it seems like this bar is either not for this truck or it's for stock arm where you can bolt the L bracket to.
Not sure it that helps or not.
Hope to see ya on the road around San Diego.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-26-2008, 02:19 AM   #3
ripdog28
ripdog28's Avatar
Re: Sway bar
I corrected it... They are POL sway bar and lower arms.
69 c-10 BBC
Old 07-26-2008, 09:59 AM   #4
Shane
Shane's Avatar
Re: Sway bar
Have you tried calling POL?
Shane is offline   Reply With Quote
Old 07-26-2008, 01:15 PM   #5
ripdog28
ripdog28's Avatar
Re: Sway bar
I did call them and explained it the best i could. They said wait for the eng to be installed but i am having a hard time believing that. What will happen when the suspension is unloaded from a bump or something? the bar be ripped off or bent up? I should send them some pictures.
69 c-10 BBC
Old 07-26-2008, 02:55 PM   #6
chevy_mike
chevy_mike's Avatar
Re: Sway bar
Looking at the pics some more, are you mounting the sway bar directly to the frame? I know stock there are brackets that mount to the frame and then the sway bar mounts to those brackets.
That might be something that is screwing things up. It's hard to tell from your pics.
Old 07-26-2008, 03:32 PM   #7
ripdog28
ripdog28's Avatar
Re: Sway bar
I do have brackets. They are for the Lowered application so don't extend down to far.
69 c-10 BBC
Old 07-26-2008, 03:39 PM   #8
chevy_mike
chevy_mike's Avatar
Re: Sway bar
Hummm... do you have any pics with the outer ends of the sway bar over the top of the A arms? I'm still trying to figure out where the main problem is.
Old 07-26-2008, 09:47 PM   #9
bagged74
its just $$$$$
bagged74's Avatar
Re: Sway bar
something is not right... are you sure thats not a rear swaybar??
bagged74 is offline   Reply With Quote
Old 07-27-2008, 12:19 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Sway bar
It's def the front bar from the POL kit. It doesn't look the same a GM bar, but the rear bars is totally different.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
