Old 07-26-2008, 08:48 AM   #1
84GMCdiesel
Fuel Gauge issues
Ok, been trying to solve my fuel gauge issue. I have a 1984 GMC 1500 2wd long bed, dual tanks, 6.2L diesel. Both tanks when full will only read just under half on the dash gauge. I cleaned and reattached the sending unit grounds on the truck frame and checked the dash gauge itself. Still can find the issue. The gauge will move as I burn off fuel and when just under 1/4 full I can take on about a half tank. Its like the gauge is only using half of the normal range. Should I try a new gauge or did fate happen and both sending units go on the fritz? She only has 52K original miles on her, but she has the age for them to go bad. Everything else works except the AC so I would like to get this fixed, along with my missing stuff for the AC. Thanks for all the help. Mike
84GMCdiesel is offline   Reply With Quote
Old 07-26-2008, 09:46 AM   #2
us111
Re: Fuel Gauge issues
i'm thinking it could be the resistor on the back
of the fuel gauge.there is a site u can buy repair
kits from but i cant remember it.maybe you can do
a site search,there has been several discussions on here
about it.or hopefully somone knows the site.
went ahead and done a search,this may help
http://67-72chevytrucks.com/vboard/s...gauge+resistor
us111 is offline   Reply With Quote
Old 07-26-2008, 03:55 PM   #3
Prong
One thing you can try is take the + lead off of the sender and ground it. Turn key on and the gauge should peg to full. If not, it's the gauge that's bad.
Prong is offline   Reply With Quote
Old 07-26-2008, 04:19 PM   #4
84GMCdiesel
I can put ground to the middle contact and hot to the left contact, or right if your looking at the gauge backwards, and it will go to full. Its very strange, I have had the dance all over the place, just not work, but not two seperate sender units give the same reading on the gauge. Both read just over an 1/8th below half when the tank is full, then if I refuel if the needle is just past the 1/4 empty mark, I can put 10-11 gallons of diesel in each tank. If its the senders, its gonna stay this way for awhile, them aint cheap, and then the hassle of droping the tanks. Mike
Tuned up diesels are handy for reversing the rectal/cranial inversion that most drives have these days, just a push of the magic smoke peddle leaves them in a cloud of diesel soot.
Old 07-28-2008, 03:14 PM   #5
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Mike, I have a guage you can try to determine if yours is faulty. If you feel like taking a short cruise south, just LMK. Jay
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
