Old 11-12-2002, 10:25 PM   #1
special70gmc
special70gmc's Avatar
Question what the h*ll is the difference???
i cant figure out what the difference between the 3/4 tonand the 1/2 ton front suspention i wanna put disks and drop 21/2 spindles up there will 1/2 ton spindles fit? it doesnt tow or carry any thing. does any one know?
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 11-12-2002, 11:06 PM   #2
imdarren
imdarren's Avatar
Someone will correct me if I'm wrong. But I think the only differance is heavier coil springs, swaybar, and 8 lugs on the brake rotors. I think the spindles would be the same.
Anyone disagree?
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 11-12-2002, 11:10 PM   #3
Johns70
Johns70's Avatar
early classic enterprises make a 3/4 drop spindel check them out.
I also know by misfortune that the crossmember it self is different at the upper a-arm mounting they take a diferent a-arm shaft also.
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 11-12-2002, 11:11 PM   #4
chevyforever
Some like em' long!
i think that the 3/4 ton and 1/2 ton spindles have a different taper where the hub/drum assembly ride. therefore, you won't be albe to use 1/2 ton spindles with 3/4 ton hub, and vice versa.
someone correct me if i'm wrong.
forever
1971 chevy c10 lwb- 300 hp 350 crate motor, soon to be more with ported and polished 62cc chamber 461 double humps, TH400, 3.73 posi, used to be my uncle's truck
1972 chevy k10 lwb- 350,4 spd, old and tired, dad bought brand new and is now mine
1968 chevy c20 lwb- 327, 4 spd, was originally a 50th anniversary truck
1990 GMC K1500-just my runaround truck
1982 Chevy K10 shortbed, new motor and new paint, another project in the mix of the others.
IMPORTS SUCK!
chevyforever is offline   Reply With Quote
Old 11-13-2002, 01:08 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Been a while since I dug around in a 3/4 ton, and I have't taken a wheel off of my one ton since april, but I think there is nothing in there that swaps out with a 1/2 ton except for the spring.
Old 11-13-2002, 10:32 AM   #6
slam33
slam33's Avatar
1/2 ton spindles will not fit. Everything is larger. Larger ball joints, tie rods, and spindle shaft
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 11-13-2002, 12:18 PM   #7
crazy longhorn
Fabricate till you "puke"
I have swapped a 3/4 ton to 1/2 ton pcs......you will be changing a lot of parts! My longhorn still has the original crossmember, & top a arms & shafts. The 1/2 ton ball joints will bolt to the 3/4 ton TOP arms, but the lower arms need to be swapped(the hole size is different for the ball joint). That gets the spindles mounted, but you arent done yet! you still haveall the steering linkage to deal with. I still have the 3/4 ton center link(my guess is a 71-72 pc), as it had been swapped to discs(3/4 ton). the inner tie rods are also 3/4 ton pcs, but the outers are 1/2 ton items. then the 1/2 ton spindles & rotors(5 lug) were bolted on.......sound like fun yet? You can get a 3/4 ton drop spindle & retain the 8 lug wheels, but I think they are designed for 71-up balljoints, tierods ,ect. Good luck......69
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-13-2002, 12:42 PM   #8
COBALT
COBALT's Avatar
I'm in the same boat you are. I just rebuilt my 3/4 ton suspension, and am going to lower it and convert to 1/2 ton later. Yes, Early Classic Enterprises makes a spindle that will adapt to 3/4 ton suspension parts for 1/2 ton conversions. You'll be able to reuse all of your 3/4 ton parts. Check them out:
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 11-13-2002, 01:04 PM   #9
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Correct me if im wrong but the front springs from 1/2 ton and 3/4 ton trucks are fully interchangeable. THey just cant carry as much. Im gonna hopefully put 1/2 ton drop spring up front on my 3/4 ton and hopefully they will also improve ride quality a bit.
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 11-13-2002, 01:26 PM   #10
Fast68Chevy
Fast68Chevy's Avatar
yes springs will physically fit, and so will 1 ton springs, the pockets in the cradles and in the arms are all same diameter, the weight rating of the springs is the only difference and its not a huge difference between these ratings,
and the cradles are same cradle up through 1 ton, its the spindles that change from 1/2 to 3/4 ton. 3/4 ton ones are alot larger than 1/2 ton ones as previously mentioned.
good luck
Fast68Chevy is offline   Reply With Quote
Old 11-13-2002, 09:31 PM   #11
special70gmc
so if i buy these 3/4 drop spindals can i bolt a disk brake kit for our year trucks on no problem? doesnt sound too bad but im sure theres a catch
1958 belair 2door
Old 11-13-2002, 09:36 PM   #12
special70gmc
o yeah i just put a brand new booster and mc on the truck i hope that doesnt need to be replaced/
1958 belair 2door
Old 11-13-2002, 10:04 PM   #13
crazy longhorn
You should be ok on the booster, but will need to change the master when you convert to discs(that wont be too big an ouch). You might check with some of the Vendors on the board on the spindles......Im sure GMC paul , or Wes will give you the" straight dope" on conversion pcs. good luck.....crazy longhorn
