![]() Join Date: Sep 2006
Inexspensive summit gauges
I have time to think abouit it but they seem to be ok and the price aint bad. They are silver faced with blue back lite. The speedo sells for $82.95 and you have to buy a sensor with it for another %54.95.. That sucks but you have to do what you have to do. The Tach sells for $42.95, fuel sender is $41.39, Water temp that goes up to 300º goes for $38.95, and the oil pressure gauge is $44.95. You can get the oil, temp, and volt meter in a kit for $99.95 though. As seen below http://store.summitracing.com/partde...0&autoview=sku .. They are not flashy nor are they big named but for the low buck build they are not bad. I might even try them out but will probably go with the ultra lite II ...
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 07-26-2008 at 03:24 PM. |
Re: Inexspensive summit gauges
One more.. The volt meter and it sells for 36.95
I have a set of electrical gauges for oil/water/volts and it seems to be plenty accurate enough. I really like the way the needles sweep around when you power them on.
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster |
Those look good. I went with sport comp's for my c10. Haven't installed them yet, as they will go in with a custom dash.
