Old 07-26-2008, 06:34 PM   #1
oldsmobilekindofguy
Solenoid help please
I need to know which side of the starter solenoid is the battery side, I have a Ron Francis wiring kit which is really nice and easy, except my solenoid has an R and an S on it. Which one would be the battey side or positive side?
1967 c-10 longbox project, check it out in projects
1969 c-10 parts pickup, twisted frame
Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block
oldsmobilekindofguy is offline   Reply With Quote
Old 07-26-2008, 07:29 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Solenoid help please
the battery goes to the one big post that isn't marked.
The purple wire, or trigger, or start wire (from the neutral asfety switch) goes to the S, and the R is not used unless you have the old points set up.
There is no small battery terminal on the starters.
Old 07-27-2008, 11:02 AM   #3
oldsmobilekindofguy
thanks that helps alot
