Old 07-26-2008, 07:55 PM   #1
glimmertwin01
glimmertwin01's Avatar
67 Panel
hey guys maybe you could all chime in and offer your advice or encouragement/ discouragement..
I am on Vacation and stumbled across a 67 Panel truck.... its basically a solid truck in need of some TLC.... all the good stuff that you cannot replace is there, and not rotten, but it has a 3/4 or 1 ton frame under it.... ( my guess is a 1 ton because it has a double stack of leafs . It also has a GM corp 14 axle, the hull tag indicates a 157 as the first 3 digits... ( 1/2T V8 67)it appears to be originally and orange truck that a P/O painted over in Met. Blue... (inc the TSID dash sticker) so I cannot ascertain all the info
thegood
the frame is clean the floor is solid and all there, the panels are great any minor rot can be replaced with aftermarket panels.... minor floor rot on DS it has side mouldings.... like a CST would have...and the current owner (who put the clip on it) salvaged the A/C system from the 72 (but not the dash panel)
the bad.. it has a 72 GMC 1500 clip on it..and the front core support mounts do not line up withtheframe mounts....( about a 1/2 in off on the front to back axis)
basically all there to make it a good truck... the battery was toast and it wouldnt take a jump... I couldnt hear the 72 350 run.... I will go back Mon night to hear it run and spend a lil more time looking it over..
basically anything I should look for?
to me these trucks are liek HENS TEETH and very cool
I think it might be awesome on a 4x4frame...
let me know your thoughts... thanks
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 07-26-2008, 07:59 PM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: 67 Panel
If its solid, and you like it, I say go for if the price is right. Panels are very cool, and they are getting really hard to come by.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 07-26-2008, 08:11 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 67 Panel
If it is in any shape bodywise then it's worth saving.A frame isn't hard to come by and mechanics are fairly reasonable if you don't get too wild.If the price is right and you can build it or save it to build later then it's a no brainer.Changing front clips and such isn't a big deal.In actuality the SPID is not a big deal since most panels were sold as delivery trucks or workhorses they didn't get many options.In fact the passenger seat is listed as an option.Most had base V-8's or 6 cyl and 3 speeds.4X4 models were very rare and if I found a factory 4X4 I would want to restore it.The only 4X4 factory truck I have ever seen was a 292 4 speed truck.I have never seen a panel with any other than base trim unless it had been added.I'm not an authority on Panels but I have owned 3 and have had one since the late 1970's,so I have done as much research as possible.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-26-2008, 08:19 PM   #4
glimmertwin01
Re: 67 Panel
it is a 2wd... the price is $3500 kinda steep since i have not heard it run.... i hate to see this go to Evilbay it would have to be trucked 420 miles west why cant i find this stuff near my home???
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 07-27-2008, 06:17 AM   #5
Re: 67 Panel
I question what frame that Panel is on.It may be original.There were no 1t Panels like this.All the frames were the same,12t/3/4t.I don`t know why the core support doesn`t line up with the mounts...they should no matter what 67-72 clip it has.14-bolts never came in these trucks.It should be a round housing,an HO52 Corporate rear.
Old 07-27-2008, 09:26 AM   #6
glimmertwin01
Re: 67 Panel
i know this... thats why i have subjected the $64,000 question to you folks.
it is the type of frame that 67-72 trucks have.... I was thinking that the body may have been mounted slightly forward.... (the cab mounts on my truck seem to have some "wiggle room") anyhow he wants 3500...
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 07-27-2008, 10:33 AM   #7
Re: 67 Panel
That`s not all that bad.Especially if it`s a decent body.These are about rare.I could have had a`67 for that much that a guy had added CST stuff,5-lugs,350/TH350 but had rust bad in the tail...I passed.
