Easy Does It
wiring question-
Could someone help me with how to rewire the passenger side engine harness. I am using a HEI distributer so I tossed the coil. What do I do with the green wires -or can anyone tell me what color wires go to what? thanks
![]() Join Date: Aug 2005
Re: wiring question-
Believe purple is starter and the braided tan one should be replaced with a 10awg wire for the HEI. You can get a new spade to crimp on for the firewall plug. The others I'll have to look up.
Easy Does It
thanks for the response, I believe the blue is for oil gauge and green for temp gauge? the starter has a place for two wires the purple was one and the white also ,but im not sure exactly -now that i've changed over to the HEI dist. any help would be great. thanks
purple and blue went to solenoid, dark green goes to temp sensor, as for light green and brown, one goes to the coil, and im not sure about the other. the stock oil gauge wasent electric.
good luck... John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
1961 crewcab
hewlett got it, light green is the coil, and the brown is a silver wire that acts as a ballast resistor.
just ditch the brown and light green and you should be good to go. |
Easy Does It
what wire goes to the distributer? the white? do I need to run that to the starter first? then come off that to dist. ? thanks
1961 crewcab
If you are running hei, none of those.. just run a wire from the batt terminal of the hei to the port on your fuse block that says ign switched(one that is hot when the ignition is on).
the dark green is the temp guage, and the other two should run back to the ign switch, one is on the hot terminal of the startre, and the other is for the start part of the solenoid. the old coil wire which you will delete should be easy to spot, because it runs in that harness, but only runs from the starter to the coil, it does not go back into the cab. the silver wire, brown coated wire that performs the job of the ballast resistor should have been hooked to the same "run" terminal of the solenoid, just tape that one off, and don't hook it up. |
#8 | |
Council of the Elders
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times Last edited by billydonn; 07-29-2008 at 08:07 AM. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Just a couple of things I'd like to add:
1) make sure you have a full 12V to your HEI with the key "on" 2) I usually run a 10 ga wire to the HEI. I think the OEM wires to the HEI were 12 ga, but I like the added insurance of the 10 ga wire.
#10 | |
1961 crewcab
![]() ![]() seems like on the one I did it was for a warning light dash, the one I am doing now is a gauge dash,,, so I am thinking there are only 3 wires in the firewall plug that I need?? should be dark green( temp sender) purple (start side of starter) , and black (starter to ignition switch??) the others would be coil and should be omitted??
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Blue - original oil pressure sender for gauge cluster w/ lights
Purple - start side of starter solenoid(closest to engine block) Light green - "cold" side of temp sender w/ warning light cluster-green light Dark green - "hot" side of temp sender w/ warning light cluster-red light cloth covered white( maybe brown now)- resistance wire from firewall plug to + on coil (this is the wire to replace with 10ga to BATT on HEI) no reason to run all the way to fuse panel. There would have been a yellow wire originally from the RUN side of starter solenoid that would have spliced with the resistance wire at the coil- this can be eliminated now. If you have a gauge cluster now- the oil pressure will be mechanical with a hard line from engine to gauge. You will use the dark green wire to the temp gauge. You can just tie up the blue and lt green wires out of the way. |
![]() Join Date: Mar 2005
This is an excellent question, with outstanding answers, for a very worthwhile upgrade. The information you can get on this site is outstanding.
This should be in an electrical "sticky".
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
