Keepin it old school
Door Handle replacement.
I need to get new door handles or new lock mechs so I can lock my doors. I didnt get any door keys when I bought the truck..
Never seen the inside of one of these doors. Is it a easy job? Do I have to remove the glass to get to the back side of the handles? Thanks guys.. |
Easy Does It
Re: Door Handle replacement.
you could buy a complete lock set they come with new keys, door and glove box locks and ignition. try the truckandcarshop.com
what year truck?
our '66 is simple, 2 Phillips head screws holds the handle on, you just roll the window out of the way, can even get a drill in there too, i have never changed the locks though
![]() ![]() Last edited by joe231; 07-27-2008 at 12:17 AM. |
#4 | |
![]() Its a 63.. The infamous knee knocker..I already found out the hard way why they call it that... Last edited by Bazooka; 07-27-2008 at 12:42 AM. |
ha ha, yeah
![]() might be the same, not sure
Moderator
![]() Join Date: Jun 2008
They're a piece of cake. Just do one at a time so you can reference the other if needed. And if you by aftermarket, make sure you line up the bolt threads in the door handle correctly. I was in a hurry once and did not pay close enough attention and broke the bolt off in the handle. I had to drill and retap it to get it to work. Ugh!
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
Easy Does It
60-66 are the same. once you unscrew the door handles from inside take out the old lock then you just slide the new locks in the same, the only hard part is the ignition key you will need to place a paper clip in the small hole then turn the key to pop out the old one. then you can use 1 key for every lock.
Roll the window all the way up. Remove the inside door regulator and window regulator. Remove the interior door panel. Remove the two phillips head screws from the exterior door handle. The lock mechanism is held in place with a "C" clip. Remove the "C" clip and the lock assembly, caps and spring will come out. The correct setting of the key opening is vertical when replace the locking mechanism. Reassemble in reverse order.
For a matching set of ignition, glove box and door locks, try: www.classicparts.com www.bowtiebits.com I have purchased this set from each and installed with no problems. I also recommend replacing the door handle gaskets, which are available from Classic Parts and Bowtie Bits and www.lmctruck.com. This will keep the handles from contacting the paint directly. I hope this information is helpful and good luck with your project. Last edited by LILRED66; 07-28-2008 at 09:57 AM. |
