Old 07-27-2008, 01:36 AM   #1
Blizz
Blizz's Avatar
Question about AC in 96 Tahoe
Hey guys, I'm new to this forum, I'm usually in the 69-72 Blazer forum. Anyways, my question has to do with the AC on my 96 Tahoe. Every summer for the past few years, I've had to put in two full cans of freon into the Tahoe and it'll last thoughout the summer but over the winter it all leaks out. All signs point to a slow leak. Now I've had several people tell me that this is a common issue with that year GM trucks and that it was related to the compressor. So before I throw down $200+ for a new one, I need to make sure that's what it is. Anyone here have any ideas? Or is the compressor thing for sure?
'72 K5 CST Blazer 4x4 in perpetual progress
'96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon
Blizz is offline   Reply With Quote
Old 07-27-2008, 09:45 AM   #2
cjracing15
cjracing15's Avatar
Re: Question about AC in 96 Tahoe
It is probabally either the comp. seals or more likely the o-rings on your refrigerant lines. I would try the o-rings first. Much cheaper.
The fleet
94 Chevy 4x4 reg cab
2018 Traverse (wifes car)
1977 SWB stepside
1949 Chevy truck
cjracing15 is offline   Reply With Quote
Old 07-27-2008, 11:01 AM   #3
pumpkin
pumpkin's Avatar
The vortec 350's do have a problem with the compressors leaking. The replacements also have a problem. This is due to the 4 bolts that mount the compressor. It tends to twist the compressor, causing it to leak. On the replacement ones I have installed, they come with instructions on how to square up the mounting. It would be a good idea to add some dye, the next time you recharge the a/c, that way you can find, for sure where the leak is.
pumpkin is offline   Reply With Quote
