Old 07-27-2008, 10:14 AM   #1
orange66fleet
Lowered in Cleveland
upper control arm cross shafts
Need some help on the best way to remove old cross shafts. I can only find meterials relating to later models that have a nut you take off and then chisel the bushing out. The 63 has a lager nut (1 3/8) that tightens onto the shaft. That is my observation by just looking at the new one.
orange66fleet is offline   Reply With Quote
Old 07-27-2008, 11:25 AM   #2
YOLO
Custom Truck Lover!
YOLO's Avatar
Re: upper control arm cross shafts
remove the nuts on both ends and twist out the shaft. Use a vice to grip the a-arm. You can use a heavy duty screwdriver or bar to put in the holes of the shaft (two bolts that hold a-arm to frame). It is not that hard to do, but may be hard to remove without penetrating oil.
Squarebody guy
YOLO is offline   Reply With Quote
Old 07-27-2008, 07:35 PM   #3
83burban
With the shaft still bolted to the cross-member (2 lateral bolts) use a large wrench to twist the bolts off, then removed the shaft. and replace the same way.
83burban is offline   Reply With Quote
Old 07-28-2008, 06:26 PM   #4
orange66fleet
Well my grandfather gave me a 35mm socket from a friend at the dealership and the caps came right off. I finish both in a matter of seconds. Man I love air tools, I do not know what I would do without one.
