Old 07-27-2008, 12:14 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Need a liitle help her with power steering bracket
Anybody have any clue how this thing goes on its been about 3 years since I removed it and am haveing some troubles getting it back together..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-27-2008, 02:32 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Need a liitle help her with power steering bracket
That is different than mine, sorry -- but if it helps at all, on mine the slot is on the upper stud on the PS pump, with the lower pump stud being the pivot point.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-27-2008, 08:24 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
Can anyone help me out here possibly?
MEMBER #6377
Project "7DEUCE"
Old 07-27-2008, 08:26 PM   #4
d10s69c10
Built 4 Speed
d10s69c10's Avatar
*Whips out Camera* Brb!
never mind mine looks nothing like yours. but that does look close to my alternator bracket.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 07-27-2008, 08:36 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
Thanks but ya this would be for the power steering on a 454 out of a 75 chevy....
MEMBER #6377
Project "7DEUCE"
Old 07-28-2008, 12:03 AM   #6
FRENCHBLUE72
PROJECT 7DEUCE
Anyone?? imma tring to get this thing fired up...
MEMBER #6377
Project "7DEUCE"
Old 07-28-2008, 12:39 AM   #7
d10s69c10
Built 4 Speed
d10s69c10's Avatar
i can go check out my big block in the morning and get you some pics. but if i remember correctly that 1 of a 3 piece set up on the drivers side. the 2 tp brackets attach to a cast y shaped piece and then another piece of stamped steel below. il post pics first thing.
496/T-56 in worx.
Old 07-28-2008, 07:52 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
Sweet I have the lower piece mounted already and was not sure if I was missing a piece or not..
MEMBER #6377
Project "7DEUCE"
Old 07-28-2008, 03:49 PM   #9
70rs/ss
70rs/ss's Avatar
This piece bolts to the front of the pump and the bolt that slides through the slot goes to the hole on the H2O pump. Hope that helps? The square hole on the end of the bracket is for the AC comp bracket that mounts up top. This is all from memory, but I think it is correct?
70rs/ss is offline   Reply With Quote
Old 07-28-2008, 11:02 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
anyone else have any pics????
MEMBER #6377
Project "7DEUCE"
Old 07-30-2008, 10:05 PM   #11
FRENCHBLUE72
PROJECT 7DEUCE
t.t.t one more time..... anyone with pics????
MEMBER #6377
Project "7DEUCE"
