Old 07-27-2008, 04:10 PM   #1
oldsmobilekindofguy
Where is the neutral saftey switch on a SM 465?
Does anyone know wherer the neutral saftey switch is on a SM465? I am in the middle of wiring it up and I couldn't find it.Please help.
Thanks in advance.
1967 c-10 longbox project, check it out in projects
1969 c-10 parts pickup, twisted frame
Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block
oldsmobilekindofguy is offline   Reply With Quote
Old 07-27-2008, 04:19 PM   #2
milled
milled's Avatar
Re: Where is the neutral saftey switch on a SM 465?
My sm420 has one in a 70 chev it should be around the clutch petal.
1970 k20 350 4speed hd44 14b
Circumventing the language filter is against site rules
milled is offline   Reply With Quote
Old 07-27-2008, 05:07 PM   #3
Wrenchbender Ret
They didn,t use one tlll a few years later. Then it was on the top of the clutch pedal. The backup light switch was on the side of the trans. tower. It was not on the real early models.
Wrenchbender Ret is offline   Reply With Quote
Old 07-27-2008, 05:53 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I don't think they did that till the mid 70's
Old 07-27-2008, 05:59 PM   #5
prg machine
prg machine's Avatar
What the heck ...................................just put the clutch down and turn the key. If ya need that dang safety switch ya shouldn't be drivin.........
I'll never forget a bud of mine droe over 100 miles to retrieve his wife who couldn't get the car to start......................
it was an auto................................................................................................ .......................
she didn't have it in park!!!!
I guess the conversation was short to none for several days after that one!!!!!
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 07-27-2008, 06:01 PM   #6
prg machine
Thanks in advance.
Take no offense to my previous comment.....................I am sure you have a good reason to find the switch..................I couldn;t resist being the wise guy.
383 .040 over
Old 07-27-2008, 06:17 PM   #7
Longhorn Man
I personally find a lot of these 'safety items' to just make the general public that much stupider.
Wehen your grandfather was learning to drive, he was taught to always... ALWAYS depress the clutch pedal to the floor before hitting the ignition switch.
Is that so hard?
Now there's a generation of people that if it wasnt for the switch, they would do lots of damage.
Like my response to my boss when he saw my throwing my NSS away after doing a van tilt conversion. He asked me, "what if you start it in gear?"
I simply tell him I'd get what I deserve, for shutting it off in gear, and leaving it that way."
Old 07-27-2008, 07:51 PM   #8
oldsmobilekindofguy
I grew up learning how to drive a stick that is not the problem, it is just one of the steps in my Ron Francis wiring kit and i figure if it was there Iwould put it in just incase I sell it or something
Old 07-27-2008, 09:59 PM   #9
Don`t worry.There is none on these trucks.
Old 07-27-2008, 10:27 PM   #10
Longhorn Man
olds guy, I didn't aim that at you....but rather to society in general. It all falls under the "it's not my fault" mentality.
Old 07-28-2008, 10:28 PM   #11
oldsmobilekindofguy
i know what you meant, but actually there is a neutral safety swich on these transmissions because I found one for sale and then found it on my transmission
Old 07-28-2008, 10:31 PM   #12
oldsmobilekindofguy
This is it
Old 07-29-2008, 06:14 AM   #13
Longhorn Man
pretty sure that's the back up light switch
Old 07-29-2008, 06:37 AM   #14
Blazer1970
Blazer1970's Avatar
The 465s from this era have a backup light switch, and a lot of them have a high gear indicator switch for the TCS system. Definitely no neutral safety, and I don't think a switch was ever used on the tranny for this - it worked off the clutch pedal as noted above (but this was not used in the '67 - '72 era).
Blazer1970 is offline   Reply With Quote
Old 07-29-2008, 07:15 AM   #15
The first truck I noticed it in was an`80.I think my`78 had one.Those trucks had the later SM435.But,as mentioned,it`s a switch activated off the pedal arm.I disconnected mine,just like I do headlight and seatbelt buzzers.I feel I know what I`m doing when in the driver`s seat.Silly,huh?
Old 07-29-2008, 09:39 AM   #16
68gmsee
Active Member
68gmsee's Avatar
Re: safety switches and other assorted safety features on our vehicles and all of our lives. Some are good others are overkill. We have become accustomed to being protected to the point where nothing is our fault and lawyers love to jump on anything they can pin on someone else.
Lets say you disconnect or leave the safety switch out of your vehicle and happen to sell your truck. And lets say they start it in "drive" and cause major damage to someone else or themselves. A lawyer will jump on this like fleas on a farm dog.
All I'm saying is be careful and don't assume that everyone out there is knowledgeable.
68gmsee is offline   Reply With Quote
Old 07-29-2008, 04:08 PM   #17
Longhorn Man
You are absolutly right, and that is a point I am normally the one pointing out.
Old 07-29-2008, 04:08 PM   #18
oldsmobilekindofguy
it is called a neutral saftey switch on the website, does someone have a picture of the backup light switch so I can see the diference, the one on the side of my transmission is busted off on the front What is left of it looks like the pictre ahown above, you guys are maybe right but I need to figure this out
