RPO B4U code performance dash cluster?
I want one real bad for my 1991. It has a 110 mph speedo in it with a 6000 RPM tach. Is there a place that sells them? Are they available from GM? Anyabody have one? Im positive they came in 454SS trucks. Hmm...need a wrecked 454SS
. thanks. Brandon
Mine- '91 GMC RCSB 2wd, 350tbi, 5 speed, 3.42 G80 -Dad/Me Projects/Toys 75 SWB Silverado Factory 454, Th400 87 SWB Silverado 305tbi, 700r4, 2.73's...17.4 @74mph a couple dodge cummins trucks. PLEASE DO NOT MESSAGE ME ABOUT FACTORY TACH DASHES, I AM NOT MY FATHER AND I KNOW VERY LITTLE ABOUT THEM. Thanks
97' Tahoe 2dr/2wd
Re: RPO B4U code performance dash cluster?
I have read some stuff about these on other boards. From what I remember 88-91 have the same plug for the instrument cluster and use a DRAC inside the instrument cluster. 92-up have a different style plug for the instrument cluster and use an external drac. The only yearthat a tach dash was made that is plug and play for 88-91 was offered for 91 trucks. search on fullsize chevy . com i think that is were i found out all of this. the drac in the 88-91 cluster is "burned in" at the factory and if you swap to a different truck, with different trans, rear end gears, tire size, you have to buy a kit from gm to erase the factory burn and then use the supplied chip for your application. I have a 91' tach dash from a 1/2 ton 2wd 350/700r4 3.42 gear. I have though about putting it in my truck (90' 350/700r4 3.08 gear) I would have to buy the kit from gm to change the settings in the cluster, i think the kit is around $50-60, I just have not had the extra money to do it yet.
A lot of people change to the 92-94 tach cluster and use the 92-94 Drac and i have seen some instructions on the net about how to make this drac reprogrammable at home with the help of radio shack. http://www.fullsizechevy.com/forums/...h+dash+swap+91 Last edited by tommie; 07-27-2008 at 11:16 PM. Reason: add link |
97' Tahoe 2dr/2wd
Also,
I do remember that some of the tach dashes had different top mph readings, search the net and you can prob find that answer to this one also.. whoo hoo!!! 400 posts!!!! Last edited by tommie; 07-27-2008 at 11:23 PM. Reason: i have 400 posts!!! |
| Bookmarks |
