Old 07-27-2008, 09:02 PM   #1
RicksTrucks
RicksTrucks's Avatar
Idling rough after pulling a stump out
69 SWB with 350 crate, 4 barrel Edelbrock carb.
Was using the truck to pull out a small tree stump. The tractor wasn't running and the wife wanted it out.
Pulled a few times and a couple of the times it killed the engine when I got to the end of the chain. The time before the stump actually came out, when I restarted it, it ran rough. Finished the job and the checked it out.
Idles a little rough in neutral. Put it in drive and it is worse, but seems to drive okay.
I check the distributor (HEI) to make sure it was tight and didn't move and it seemed okay. Any ideas?
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 07-27-2008, 09:09 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Idling rough after pulling a stump out
You may have knocked a vacuum hose loose. I'd start by checking all the hoses vacuum hoses including the vacuum modulator.
Another possibility, is that you may have dislodged some sediment from the gas tank an possibly got some gook in the carb.
68gmsee is offline   Reply With Quote
Old 07-27-2008, 09:16 PM   #3
RicksTrucks
Thanks. Did forgot to mention that I did check all of the vacuum hoses. Have had that happen before. I do have a clear inline filter and did notice on my way back from Arkansas Friday that there wasn't much fuel in the canister, just at the bottom - where I have seen it full in the past. In fact I think it was full when I was checking the vacuum hoses before my trip.
I will look at the fuel system some more.
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
72 LWB C-10
72 Blazer 4x4 4spd
Old 07-27-2008, 09:49 PM   #4
matthufham
if you have rubber fuel lines, one could of kinked. or check the vacuum line that goes to the tranny, if you were off road, then something could of snagged it?
matthufham is offline   Reply With Quote
Old 07-27-2008, 10:29 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
shook a plug wire off maybe?
Old 07-27-2008, 11:16 PM   #6
RicksTrucks
Plugs wires good. In fact I changed the plugs thinking maybe I had fouled one. So as far as I can tell plugs are good, wires are good, all vacuum lines check out. May pursue the fuel angle next. Verify that the filter is not filling up, which may indicate clogged fuel line somewheres. Got several extra tanks in case I got stuff in mine.
Thanks and keep the ideas coming.
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
72 LWB C-10
72 Blazer 4x4 4spd
Old 07-28-2008, 09:59 AM   #7
matthufham
distributor cap didn't hit the firewall? so it's good with a good rotor? maybe the distributor drive gear is getting worn. i wouldn't assume valvetrain issues (timing chain, valves, lifters, pushrods) since it's a newer gm crate that's been checked.
i have a edelbrock 1406 and i had to raise the float levels, clean my jets, and upgrade the needle and seats to the off road ones to get mine running right, don't know why. it's real easy to open that thing up now though. check the choke to see that it's open a little until warm, then fully open. assuming electric choke.
Old 07-28-2008, 06:17 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I have one of the glass filters on mine (I know, I know) and when it wasn't filling up, I thought I'd check the hoses. Good thing....they were toast, which is to say my truck could have been if a hose had leaked gasoline onto a hot header. After changing the hoses, the filter filled up and stayed full, and the truck started much more easily.
Member Nr. 2770
Old 07-28-2008, 09:29 PM   #9
RicksTrucks
I checked the fuel filter this morning and it was full when I started it up and still ran rough. The fuel hoses should be good - replaced the last bad one a few months ago. But thinking about going through the whole fuel system this weekend.
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
72 LWB C-10
72 Blazer 4x4 4spd
Old 07-28-2008, 10:21 PM   #10
Wookiee
Sounds like what happened to me a couple weeks ago when I Pulled some rocker studs. Tached it up a bit much on the interstate, but I know you can do the same thing trying to yank a stump. Ran the same way. Idled kinda rough, then got worse in gear. Hoped it was something simple like a vaccum leak or fouled plug or something, but all that checked fine. Ran a compression test and found nothing on 1&3. Still trying to find time to re-stud the heads. Hope it's something simple, but I can see where it could be something less so.
1970 CST-10 350/350 turbo
1978 Camaro Z-28 Clone 350/Saginaw 4-speed
Wookiee is offline   Reply With Quote
Old 07-28-2008, 10:23 PM   #11
RicksTrucks
What was the cause of no compression? Not familiarwith re-studding heads.
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
72 LWB C-10
72 Blazer 4x4 4spd
Old 07-29-2008, 09:08 AM   #12
Huck
Huck's Avatar
Start at the basic compression test then go from there. You could have loosened a rocker stud in the head, popped off the upper tip on a valve shaft, etc. There are lots of things that can cause a mis. Use a spark tester for each cylinder, recheck timing--hook up a vacuum gauge to see what it reads--look at GMC Pauls tech tips on vac gauge tune up.
A mis rough running engine at idle that ran fine before ---i would suspect ignition (plug, plug wire, cap, vac) before I would supect fuel. But that said, I have been surprized many times too!!
Huck is offline   Reply With Quote
Old 07-29-2008, 09:18 AM   #13
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Exclamation Re: Idling rough after pulling a stump out
It's possible that you could have a broken valve spring causing your miss also. My truck did this after I passed a friend of mine at high speed....
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 07-29-2008, 07:52 PM   #14
Wookiee
The rocker studs pulled out of the head, causing the valves to no longer open. By "re-studding", I meant I decided to replace all my studs with the screw in type. I agree with Huck though. Go through and check the easy stuff first. More than likely that's where the problem is, but if not check compression and you've got an idea of what else to look for.
Old 07-29-2008, 08:54 PM   #15
rstewart09
rstewart09's Avatar
My have broken a motor mount and engine is just bouncing around in there.
The start of a new toy
1967 GMC 3/4 ton
rstewart09 is offline   Reply With Quote
