what do I need.
What all do I need to convert a set of Blazer Buckets to fit in My truck. Seats are out of a 72 and my truck is a 72.
thanks for all the help, and if there's a write up on this hook me up.
1972 SWB Cheyenne |
Roadtrip!
![]() Join Date: Feb 2003
Re: what do I need.
You will need the pass. side stationary brackets. (the blazer has the flip up brackets) Should be ok on the drivers side. Remove the plastic backs on the seats if you wish...
You will have to drill a few holes to bolt them down if your truck didn't originally have buckets, but i think the outer holes will line up. Good luck.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: what do I need.
actually if you have the original blazer mounts they can be used for the passenger side also with slight modification to the release handle/l i used a set for a number of years and it was quite handy having the flip up seat for behind seat storage issues
like said a few holes need to be drilled for whatever mounts you use
