07-28-2008, 02:20 PM | #1 |
Keepin it old school
5x5 bolt pattern rear conversion
Whos got the best deals on the parts to go about switching to 5x5 bolt pattern in the rear?
I want to use the original rearend thats in it... I know I need to buy axles and get New drums.. Early Classics is like 20 min from my house so I can pick everything up in person and save on shipping charges. I will have to pay taxes tho.. Early Classics has the axle kit with bearing and seals for $320 They also have the brake kit with everything needed to redo the brakes for $289 |
07-28-2008, 02:59 PM | #2 | |
Re: 5x5 bolt pattern rear conversion
Rear axles Last edited by leftcoast66; 07-28-2008 at 03:04 PM. Reason: added link |
07-28-2008, 04:23 PM | #3 |
Guys If I use brakes for a 71 Pickup Will I also need the backing plates from the 71? I just priced everything except the backing plates from autozone and its WAY cheaper then buying the kit... About $135 cheaper!!
07-28-2008, 04:50 PM | #4 |
Not sure, but measure your drums and compare to the '71's
you could possibly use your brake stuff with the '71 drums. I don't think you will need to change the backing plate to use the '71 stuff, the different years should be very similar, I don't think drum brakes have changed much through out the '60's, '70's, and '80's
CHEVY ONLY |
07-28-2008, 05:30 PM | #5 |
It would be awesome if I could get away with just switching the drums and axles!!
Has anyone done this and retained there original backing plates?? Autozones site says that 63 and 71 both have 11x2 inch brakes.. Last edited by Bazooka; 07-28-2008 at 06:16 PM. |
07-28-2008, 10:42 PM | #6 |
Council of the Elders
It's been many years but I'm pretty sure I just changed the drums and redrilled the axles. You certainly don't need the bearings and seals unless you just want to change them. You might check and see if the wheel cyllinder part numbers are the same for the 63-71s.
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times |
07-28-2008, 11:19 PM | #7 |
60-66 Nut
I haven't done the swap but I think you should be able to use the backing plates on your '63 since the brake shoes are the same. Along about '75 or so GM went to 2 1/2" x 11" brakes on the C10's. One thing you may not be aware of is that your '63 has 17 spline axles and AFAIK all the 5 lug conversion axles are 30 spline. This means you'll have to swap your 17 spline spider gears for the 30 spline ones. That is unless the axles you are looking at come in either spline.
07-28-2008, 11:23 PM | #8 |
what is AFAIK?
CHEVY ONLY |
07-28-2008, 11:40 PM | #9 |
60-66 Nut
07-28-2008, 11:58 PM | #10 |
ok, now i see...thanks
CHEVY ONLY |
07-29-2008, 12:15 AM | #11 |
60-66 Nut
This is the only kit I could find doing a quick search....it's a little spendy but it includes everything and it gives you an idea what I'm talking about.
http://www.brotherstrucks.com/prodin...number=RAC6364 Before you get too excited, I'd check and see just what is in your diff. in case someone has changed it during it's lifetime. If your backing plates are pressed onto the axle tubes it is an original '63 diff......but I'd still check the internals.
07-29-2008, 06:59 AM | #12 |
Just redrill what you've got, axles and drums both.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 |
07-29-2008, 08:01 AM | #13 | |
07-29-2008, 09:52 AM | #14 |
07-29-2008, 09:58 AM | #15 |
If you have a good drill press so you can get the holes straight you can do it yourself for free. Most factory steel wheels are hub-syntric meaning they fit really well around the center hub and don't depend just on the lugs for centering. Because of this, you can use a wheel as a guide for where your new holes need to be. The wheels fit plenty tight enough on the center hub to insure you are centered and true.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 Last edited by HotRodYJ; 07-29-2008 at 11:28 AM. |
07-29-2008, 03:29 PM | #16 |
Yesterday evening I just made the decision to run a different set of wheels for now... so I ordered a set of (4) 15x6 smoothies that will work with my mismatch bolt patterns. I already have a set of baby moon caps to use with them to cover the lugs.. So that will save me some money.. The wheels only cost me $212 dollars for the whole set of 4. Cheaper then the wheels i was going to run if I had changed the bolt pattern. I have ran smoothies before on my old 51 Chevy pickup and like the look of them so it's all good. I am going to sell the wheels that are on my truck now to get my $$ back. So it's going to end up not costing me anything.
My truck is going to be in the shop soon for some extensive work and I needed some wheels that would tuck The offset and width on my current wheels wouldn't work Last edited by Bazooka; 07-29-2008 at 03:32 PM. |
07-30-2008, 10:10 AM | #17 | |
Aren't the hubs and the drums typically hardened? (At least the hubs). I'm thinking I'll need a heck of a drill press and a lot of time to drill 10 holes in those hubs (never mind filling the six holes). Seems well worth the $100 to get it done |
07-30-2008, 10:21 AM | #18 |
Never been a problem for the ones I have done.
07-30-2008, 10:29 AM | #19 | |
If it was me, I'd find a rear end out of a 71-72 chevy truck and bolt the whole thing in. I've done it twice and it's easier than drilling the axles (I've done that also) Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 07-30-2008 at 10:29 AM. |
07-30-2008, 12:15 PM | #20 | |
if you have the stuff to cut and weld you can put practically any 5 on 5 junkyard axle in there cheap, if you can find the right width anyway. scott62 is using a 9 inch F**d from a mid-late Li**oln Versailles, complete with rear disc brakes, said it cost him $150
CHEVY ONLY Last edited by joe231; 07-30-2008 at 12:23 PM. |
07-30-2008, 02:42 PM | #21 | |
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 07-30-2008 at 02:46 PM. |
07-30-2008, 10:12 PM | #22 |
What size drill bit do you use for the lug bolt holes?
07-31-2008, 11:08 AM | #23 |
07-31-2008, 01:28 PM | #24 |
Here's the lug bolts you would use
http://www.autozone.com/R,1938929/ve...ductDetail.htm They are 1/2-20unc vs the 7/16-20 on the 6-luggers On Papco's website they show the same bolt and say the knurled diameter is .535". I would figure you need a bit slightly smaller to get a good press fit. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
08-01-2008, 06:31 PM | #25 |
60-66 Nut
I would suggest having the studs you're going to use in hand before you drill and measure them. Then use the appropriate drill to give you .003 to .005 of an interference fit. Just my .02
